Re: 904 trans died behind 390 stroker, time for 727????
[Re: JohnRR]
#139062
10/21/08 11:10 AM
10/21/08 11:10 AM
Posts: 4,884 Michigan
MNobody
Michigan
Great.... well I'll find out later when I drop the trans..... Now back to the original question, Does anybody know what would cause the loss of all forward gears as well as reverse??? Is the front pump a likely guess? TBF
I think what caused it was a 904 behind that motor. for you to have lost all forward motion either you have no fluid flow of a shaft broke .
Pull a line off the trans cooler , direct it int oa bucket and start it up with the car in neutral , if you get no flow then its the pump , if you get fluid you broke a shaft .
Either way I would be putting a 727 behind that , 904's to handle torquey motors need $$$ parts .
That sound's like good advice to me from what i have read from several other post's.
Entire Thread
904 trans died behind 390 stroker ** UPDATE **
tpabayflyer
10/20/08 06:03 PM
stumpy
10/20/08 07:11 PM
dusturbd340W5
10/20/08 07:37 PM
RapidRobert
10/20/08 07:24 PM
scratchnfotraction
10/20/08 07:38 PM
tpabayflyer
10/20/08 07:55 PM
mikepar
10/20/08 09:04 PM
1BAD68
10/20/08 09:28 PM
HotRodDave
10/20/08 11:35 PM
slantzilla
10/20/08 11:56 PM
tpabayflyer
10/21/08 03:22 AM
tpabayflyer
10/21/08 03:24 AM
RapidRobert
10/21/08 03:40 AM
JohnRR
10/21/08 01:10 PM
tpabayflyer
10/21/08 01:57 PM
JohnRR
10/21/08 02:02 PM
MNobody
10/21/08 03:10 PM
tpabayflyer
10/21/08 07:50 PM
Locomotion
10/21/08 09:58 PM
tpabayflyer
10/23/08 01:23 PM
dusturbd340W5
10/23/08 01:53 PM
tpabayflyer
10/24/08 03:49 AM
patrick
10/24/08 12:00 PM
AdamR
10/24/08 12:42 PM
turbocolt2.4L
10/24/08 11:27 PM
469runner
10/24/08 11:33 PM
JohnRR
10/25/08 01:29 PM
RapidRobert
10/25/08 01:45 PM
babarracuda
10/25/08 02:35 PM
fasteddie
10/25/08 07:18 PM
HotRodDave
10/25/08 08:56 PM
MoparDonny
10/25/08 09:29 PM
slantzilla
10/25/08 10:01 PM
RapidRobert
10/26/08 02:27 AM
slantzilla
10/26/08 03:01 AM
RapidRobert
10/26/08 03:28 AM
slantzilla
10/26/08 04:02 AM
turbocolt2.4L
10/26/08 10:54 AM
slantzilla
10/26/08 12:42 PM
HotRodDave
10/26/08 05:34 PM
tpabayflyer
10/26/08 09:52 PM
CJK440
10/27/08 01:23 PM
tpabayflyer
10/29/08 06:52 PM
tpabayflyer
10/29/08 06:54 PM
tpabayflyer
10/29/08 06:55 PM
scratchnfotraction
10/29/08 07:07 PM
tpabayflyer
10/29/08 07:36 PM
scratchnfotraction
10/29/08 07:41 PM
RapidRobert
10/29/08 07:50 PM
tpabayflyer
10/30/08 12:20 AM
HotRodDave
10/30/08 12:40 AM
10/30/08 02:36 AM
MoparDonny
10/30/08 03:37 AM
tpabayflyer
10/30/08 03:41 AM
tpabayflyer
10/30/08 03:53 AM
JohnRR
10/30/08 12:39 PM
slantzilla
10/30/08 08:52 PM
HotRodDave
10/30/08 11:07 PM
MoparDonny
10/31/08 01:00 AM
JohnRR
10/31/08 01:13 AM
tpabayflyer
10/31/08 01:24 AM
MoparDonny
10/31/08 01:41 AM
RapidRobert
10/31/08 01:47 AM
tpabayflyer
10/31/08 03:57 AM
tpabayflyer
10/31/08 04:01 AM
RapidRobert
10/31/08 04:08 AM
slantzilla
10/31/08 06:45 AM
scratchnfotraction
10/31/08 12:07 PM
patrick
10/31/08 12:50 PM
tpabayflyer
10/31/08 03:07 PM
RapidRobert
10/31/08 03:16 PM
JohnRR
10/31/08 04:30 PM
5thAve
10/31/08 06:09 PM
slantzilla
10/31/08 08:51 PM
tpabayflyer
11/01/08 01:29 AM
JohnRR
11/01/08 12:48 PM
tpabayflyer
11/01/08 10:18 PM
tpabayflyer
11/01/08 11:13 PM
JohnRR
11/02/08 06:50 PM
MoparJoe
11/01/08 01:54 PM
RapidRobert
11/01/08 02:28 PM
tpabayflyer
11/04/08 04:28 AM
patrick
11/04/08 01:30 PM
HotRodDave
11/04/08 04:08 PM
patrick
11/04/08 07:16 PM
JohnRR
11/04/08 02:15 PM
tpabayflyer
11/05/08 01:23 PM
JohnRR
10/31/08 12:50 PM
turbocolt2.4L
10/25/08 11:09 PM
JohnRR
10/24/08 03:14 PM
HotRodDave
10/24/08 11:22 PM
HotRodDave
10/24/08 12:44 AM
dustpan man
10/24/08 03:19 AM
10/24/08 10:50 AM
RapidRobert
10/21/08 11:32 PM
RapidRobert
10/22/08 12:03 AM
1965_PLYMOUTH
10/22/08 12:18 AM
5thAve
10/23/08 12:32 AM
Rug_Trucker
10/23/08 03:20 AM
