Quote: Ok so back to the wiring....lol How are you going to feed the ECM a VSS signal from the mopar trans? Also Can I remove all the wires the used to go to the chevy trans? BTW I traded for a 24x/1x harness so I don't have to reengineer the cam signal problem
I know the older dodge ramcharger trucks has a vss that screwed on to the speedo gear, and then one off the rearend housing
