Yes you have to build a rear sub frame with these cars.It creates alot more work than an a-body.You would think with a bigger car it would be easier to work on.Just the opposite do to all the extra tubing for the back half.If you do a stock suspension it would make it alot easier.I doubt you could utilize the cert with stock back half in a b-body.
