Moparpoor, are you making a sheet metal interior? Looks great BTW! Ill be keeping all of my factory Interior which I know will make my life that much more difficult bit I think adds alot more personality to the car. Thanks for the pics! Gives me a good idea of what I'm up against.
Now who else sells 25.x moly chassis kits? I've always worked with s&W but their 25.3 chassis kit only works for chargers and correct me if I'm wrong but coronets/satellites have a shorter wheelbase do they not? That's alot of bars needing work before they can be fitted. Any suggestions? The above pics of the 71 B body must've had issues too. I know the kit for the Camaro I did needed alot if modifying but I thought that was more because of the stupid stock subframe up front.
