Stroker small blocks should be running ARP main studs and lined honed.
Ported Edelbrocks would easily get the job done. There are also IndyBrocks with the offset push rod holes so no push rod pinch. All you have to do is contact Brian at IMM (OU812) of Shady Dell Speed and they will hook you right up.
