Brian
What would that equate to in the 1/4, 8.50 ish?
Mighty impressive.
I'm guessing about an 8.70 ?
Our motor Dynoed at 800 HP on 2 differant machines, our best time was 9.03 at 149 MPH 1.24 60ft this is with a 6500 stall coan and PTC, 5.13 gear on a T brake, 1250 Jim Evans Dominator on Q16. If you go by MPH 149 car should E,T in the high 8.80s 90s but never could get it there, Our current build is addressing many issues from 1st build as Brett could attest to. Heads are W8 Arrington 13 degree, could use some love but who knows. We are going to get new motor running shortly so we'll see if changes made will result in more HP.
