Quote: Brian, I may have missed it in this post but did you dyno the engine?
from Wallace
Your HP computed from your vehicle ET is 875.50 flywheel HP and 787.95 rear wheel HP. Your HP computed from your vehicle MPH is 917.21 flywheel HP and 825.49 rear wheel HP.
No engine Dyno this time either. I know the math is what it is, but I might tend to believe the 875 number based on et much more than the mph based number. I was just hoping it would make 830 or so.
