The 5.2 Mag motor is internally balanced, probably has a 9.577-578" deck, and uses pistons that are reportedly lighter than the 590 gram 318 pistons. Rods are forgings, probably very similar to the 645 rods that were in every smallblock after about 1973, and the crank is cast but very durable as all 3.31" stroke cranks are.
R.
