I can't imagine ever going back to tuning without one...... The "look" of the plugs only tells you so much.......just like that number the O2 spits out only tells you so much....It shows lean and rich stumbles and you INSTANTLY know it's a lean OR rich stumble, instead of guessing and spending DAYS trying to dial it in....I just thought I had some of my cars dialed in, until I hooked my LM1 up!! lol
You can turn just ONE of the six idle mixuture screws on a Six Pack and SEE it on the O2 that's in just one pipe.........There's NO WAY reading plugs will tell you that.....
You can also see when you're PV opens up........you can watch the motor get leaner as you tip in, then watch it get instantly rich......Plugs won't tell you that and the ass-dyno isn't that accurate........
If it's a race only car that has to only idle and go WOT, you don't really need it (but it can help)........but for anything street driven, IMHO, it's a must-have......
while i agree with everything your saying, it still does not makes things perfect
example, NASCAR says the reason they are going to FI is because the motor needs to be jetted much richer then it actually needs to be because G forces will make the whole left bank lean. what good would a LM1 plugged into the rght bank of a fast roundy round car do? melt and detonate the whole left bank
if I was to tune my engine on a chassis dyno, it would be completely different than my car going down the track. my front carbs are jettd 6 sizes larger than the rear. how many guys here would do that?
PPMracing that is building Mr Sixpack's new engine has said the same thing about what i'm saying.
the only real tool that would really work is having EGTs in each cylinder.
and BTW, and Dram can back this up because i called him immediately, I was so pissed when i put my LM1 on my car because it said i was spot on everywhere from tuning at the track and looking at plugs.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
