The single metal clip is the forward most clip, there are only 2 per car, they bolt on last. The plastic clips are held in place with studs that are welded to the body, they look like nails with 1/4" dia heads. The trim is put on the plastic clips first then after being put on the car the steel clip is added as the final anchor point.
