Thanks R/T.....But I can tell you this right now, my car will be far from perfect when it comes to "O.E" correctness, etc. simply because it started out as a car that has had a pretty rough life, most of it's original bolt on parts have been scattered in the wind over the years. This one is my "Fun" build car that I plan to drive and enjoy. There will be a number of non O.E. replacement parts used simply because NOS exhaust, etc. won't make sense for a car like this, but I am doing my best to put date code correct original parts back on it where feasable/possible to bring her back as close to original as I can under the circumstances and I will be restoring most of the componants to factory correct standards.
Lots of work to do still but body and paint is a major step forward
