Had the car running again tonight. Used gas in a squirt bottle and fired right up
Tried to run it with the shut-off valve half cloed and it does seemm to be much leaner at adle but idles at around 2500 rpm then
The way it is set now only will idle at a half decent rpm with valve wide open
Even with valve about half closed I still went through about 3.5 gallons in 15 min or so of idling
I haven't touched the linkage because my buddy told me not to $@#! with it
But no way I am going to be able to drive to the lanes, make a pass and drive back using this much alcohol
Derrick
