Re: Air filters on race cars??
[Re: DemonDust]
#1715068
12/24/14 10:12 PM
12/24/14 10:12 PM
Posts: 7,506 Az
Crizila
Az
Simply put, if you wanna run an air filter, find the biggest one that will fit your application. If your car runs better with one, you have turbulence / A/F mixture issues or the carb is too big - all of which should be corrected by other means than installing an air filter. No matter how you cut it, an air filter is a restriction.
Fastest 300
[Re: D-50]
#1715071
12/24/14 11:19 PM
12/24/14 11:19 PM
Posts: 4,647 aotearoa
rebel
aotearoa
our track unfortunately has some stones lifting off the seal on the return road & after seeing 1 racer get a stone flick up from their front wheel & lodge itself into carbs butterflies, i would never ever run without some kind of filtration on my carb. the car with the stone in the butterflies took off with front brakes locked on & plowed into another racecar before the owner could shut it off. not a happy day for 2 racers that day. i'm using Frams Airhogg air cleaner. it's pretty good, virtualy no difference with it on or off, but i now leave it on.
[Re: sixpackgut]
#1715075
12/25/14 01:48 AM
12/25/14 01:48 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The K & N web site has the formula for square inches of filter to hp for no loss. If I recall it is 7 hp for each square inch of filter using the K&N type. I bought a 6 x 14 for next year. I learned the hard way it is impossible for the most part to aviod getting some dirt in the motor. When I saw the dirt film in the throttle body that did it for me.
[Re: Crizila]
#1715079
12/25/14 11:51 AM
12/25/14 11:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
and if you are going to use a "conventional" round style air filter, get one with a breathable top. Just that much more area that is seldom used.
I found the top lid causes issues on flow... you get 2 different air paths that crash into each other and in the end you get less into the carb... I also see that its worse if you have a drop base because the air is going up first then has to turn down to get into the carb.. but the side air is plowing into the lid air ... on the track I dont run a air cleaner
[Re: camastomcat]
#1715081
12/25/14 12:47 PM
12/25/14 12:47 PM
MR_P_BODY
I wouldn't run without one. Rocks and sand are a killer. Big K&N under the scoop.
I was gonna try to make a lite filter for the inlet of my scoop but never got around to it.. I cant put one in the scoop... but basically it would stop sticks and rocks
[Re: mopar dave]
#1715083
12/25/14 01:15 PM
12/25/14 01:15 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I remember a few years ago this came up and everybody was talking about how they use one of those filters that looks like a flat box with a wedge in the front all the air came in the top/front. Don't remember the name. I remember looking them up since I was looking for a better option under my 340 scoop. Too much $$ for my street effort.
Edit: looked it up on google image- 'UNI' filter
[Re: mopar dave]
#1715084
12/25/14 01:16 PM
12/25/14 01:16 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Had a big block chevy on the dyno, tuned it for max power, THEN the owner mentions he runs an air cleaner and it’s in the truck. We put it on and the engine loss 26 HP, then lean the carb back down and gained 28 HP.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#1715085
12/25/14 01:28 PM
12/25/14 01:28 PM
MR_P_BODY
When we were designing air filters and housing we designed them for the max power... ALL filters are a restriction but we had to use that to our benefit.. I prefer to have the filter element as a remote and plumb the air in with a nice radiused inlet to the carb or throttle body to straighten the air out
[Re: radar]
#1715087
12/25/14 01:34 PM
12/25/14 01:34 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Uni-Filter, they are expensive.....
http://www.hoffpro.com/category_s/95.htm
[Re: ProSport]
#1715088
12/25/14 01:42 PM
12/25/14 01:42 PM
ProSport
Akron, Ohio
If my car ever makes it to a track I will probably use a screen from Intensity, it will at least keep rocks and birds out. I can only fit a 10x2.75 air cleaner on my car and there's no way it will feed a 500" engine at WOT. Speaker covers work also, as Sixpackgut mentioned. I had a 340 Scamp years ago that ran great with a 14x5 K&N but my big block cars have always slowed down with an air cleaner so I ran for many years without one. http://intensityracingproducts.com/proseriesscreens.html
[Re: J_BODY]
#1715091
12/25/14 01:54 PM
12/25/14 01:54 PM
MR_P_BODY
UNI filter worked well with our cowl hood on our W5 mill.... unfortunately this set up came in at .75" too high, so the 4150 carb is on for the time being. I never ran a filter on the Mirada. Dang top of the carb was up in the Dart Sport hood scoop I was running.... no room.
....and yes, these are basically "bug and rock" catchers imho, kind of like the K&N filters I see in so many diesel trucks.... with blowby.
The Uni you show here.. how tall is it... I have to find something(or build) to fit under my cowl hood.. with a 4150 I can fit a 14 X 3" but with the new throttle body it sits taller... plus I have to have a spacer to clear the linkage
[Re: J_BODY]
#1715094
12/25/14 02:06 PM
12/25/14 02:06 PM
MR_P_BODY
From the measurements it looks like I might be making something... but I'll make my final measurements today when I can close the hood(still working under there so I have to clear some stuff out of the way)
[Re: J_BODY]
#1715099
12/25/14 02:51 PM
12/25/14 02:51 PM
Posts: 7,506 Az
Crizila
Az
Haven't tried running without it yet. Any debris in there could be expensive. I believe Procharger recommends a filter.
Fastest 300
[Re: Crizila]
#1715100
12/25/14 03:08 PM
12/25/14 03:08 PM
MR_P_BODY
I think I'll do like Doug did and make a base for the Uni... but I need to make a plate to seal in the cowl so I'll see what I can come up with.. first I need to get the injection running... see if I can down load the basic program today if I get the chance
[Re: WheelsUp73]
#1715102
12/25/14 05:47 PM
12/25/14 05:47 PM
MR_P_BODY
I run a 14 x 3 filter in a Ram Air Box. I picked up .2 in the qtr and 4 mph with this setup vs an open carb unfiltered with no hoodscoop.
It should since you were putting some pressure to the intake with that set up
[Re: Thumperdart]
#1715107
12/25/14 07:04 PM
12/25/14 07:04 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I use the K&N filter that mounts inside the harwood hood scoop. I really like it.
[Re: DemonDust]
#1715108
12/25/14 10:10 PM
12/25/14 10:10 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
What are you guys using for air filters? I notice if I take mine off I can Rev above 9200 rpms. Is there a air cleaner that can handle high rpms and cfm?
Or do you just run without them?
For a long time I used a K&N flat panel filter that fit inside my Harwood Mini-Aero scoop. I had to build the framework to mount it inside the scoop but it worked out well. The AFR tended to richen up gradually above 6500rpm but not enough to worry about. I think the Fram equivalent I used for a while actually flowed better. I never oiled the K&N element. The most recent engine is a 500ci B with Indy intake and 1150 Holley.
[Re: @#$%&*!]
#1715109
12/25/14 10:22 PM
12/25/14 10:22 PM
Thigh-Gap Junction
Now I use a Wix Racing 16"x3.5" filter in a homemade box, taking air from the grill area (no more hood scoop for me). AFR no longer richens up at the top end of the 1/4 mile, no speed or ET lost (ran 132.5mph at the recent bracket finals at woodburn.) It's a little different Carburetor is IN the airbox, bottom of the box is sandwiched between the carb and intake. Underside of the hood IS the top of the air cleaner (about 2-1/2" clearance for carb top). This way the filter element is as high as possible. Airbox just lifts off once the hoses are disconnected. One nice thing about running an air cleaner is that it shows you the items that WOULD have gone through the engine, all trapped outside the filter. To generate some pressure I fabbed two panels that closed off the areas above and below the grill, making it a closed space. Air coming into the grill has to go through the air cleaner or radiator.
[Re: DemonDust]
#1715112
12/26/14 11:13 AM
12/26/14 11:13 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
The Wix Racing filter is what was used on your motor in NASCAR, no hp loss in the airbox, get the tallest one you can fit.
[Re: DemonDust]
#1715114
12/26/14 03:00 PM
12/26/14 03:00 PM
LSP
Charlotte, NC
Doesn't the NASCAR air pan require duct work as well to make it efficient? The wix filters are fairly cheap if I remember correctly.
Yes, the air pan goes to a duct in the cowl, I was just talking about using the Wix Racing element.
[Re: MR_P_BODY]
#1715115
12/26/14 03:52 PM
12/26/14 03:52 PM
BradH
All I can add to this discussion is from my own on-track testing some years ago. I was using a 14" Moroso drop-base housing w/ a K&N 14" x 3" filter and the carb was dialed in for best MPH under the conditions. I swapped to a K&N X-Stream lid and back-to-back testing the car picked up .4-.5 MPH over the standard Moroso lid.
I have limited hood clearance and this was the only way to add filter area I could work out at the time. Although I've heard more than one person p!ss on the X-Stream lid, on my car it helped.
[Re: mshred]
#1715117
12/26/14 05:38 PM
12/26/14 05:38 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The trick seems to be to run enough filter surface area not to measurably restrict. For example, Holley ran a test in 1971 of air flow through a carb. No air cleaner 713 cfm Chevy hi-perf open element cleaner 675 cfm Same as above but with two filter elements stacked 713 cfm. They didn't publish the hights, but the point is once they had enough area, the restriction was the carb. (Mike Urich and Bill Fisher Holley Carburetors & Manifolds 1987 edition page 71) Another thing to consider along the line of what Mr P was describing is the impact on the bowl vents. With Holley type carbs the vent could be placed into a pressure stream, or in a weird turbulent area and that can mess up the fuel curve. A ton of ideas on modifying Bowl Vents shared at Racing Fuel Systems.
[Re: Mattax]
#1715119
12/26/14 05:51 PM
12/26/14 05:51 PM
Posts: 5,163 CT
GTX MATT
CT
How about running a bigger filter with a drop base? Is that really helping or is the drop base causing other issues worse than a smaller filter?
[Re: GTX MATT]
#1715120
12/26/14 06:01 PM
12/26/14 06:01 PM
MR_P_BODY
From the testing I did the drop base causes the air to go up then turn down into the carb... it can cause disturbance with the direction changes.. but is it greater or lesser than the small height air cleaner.. I'm sure that at some point its a wash.. but if you can go to a larger diameter that should help so the air has a longer area to make the turn
[Re: BradH]
#1715121
12/26/14 06:03 PM
12/26/14 06:03 PM
Posts: 7,506 Az
Crizila
Az
Helped on mine also. I have some issues with it disrupting air flow in to the carb, especially since it covers a lot more area than the inlet area of the carb it is sitting on. If there is an air flow disruption, I would think a lot depends on the distance of the top to the carb inlet. I still think the more filter area you have, the better.
Fastest 300
[Re: mshred]
#1715122
12/26/14 06:07 PM
12/26/14 06:07 PM
MR_P_BODY
I run a 14x5" tall K&N reusable filter...My buddy harassed me to make a pass with it off because the car would pick up.
I removed it and lost a tenth...He couldn't believe it! LOL...FWIW I would rather run it and know that my engine is getting the cleanest air possible instead of take the chance of feeding it dust and other debris that could possibly damage or wear it out quicker. I have seen people do tests where they lost no power with the filter, so hopefully mine is the same way
Did you jet up or down after taking the air cleaner off... without finding the A/F point that your engine likes for max power you didnt do anything but change the A/F ratio.. nothing is ever as easy as.. just do this or that and this occurs
[Re: Crizila]
#1715124
12/26/14 06:17 PM
12/26/14 06:17 PM
MR_P_BODY
More air is better... I'm sure that if you run a taller filter the lid has less effect on it than a shorter filter.. but air coming in from 2 different directions and 90* from another does have effect... and the closer they are the worse things get
[Re: MR_P_BODY]
#1715126
12/26/14 11:04 PM
12/26/14 11:04 PM
Thigh-Gap Junction
I have a friend who runs the 14x3 with pleated filter top. Based on results I've seen posted here in the past I got him to make a pass without it. The car lost more than a tenth but the AFR leaned out 2 points and was dead flat instead of the wacky variations it normally has. He insisted in putting it back on instead of jetting up a little so the test was incomplete. I have no doubt that the air cleaner is restrictive on this '70 Swinger with 410ci smallblock and a 350+lb driver that was sooo close to that 10.0et he desperately wanted. It most likely would have cracked a 9 if I was driving it just due to the weight reduction. Logging AFR will show a restrictive air filter as richening at higher engine speeds.
[Re: GTX MATT]
#1715127
12/26/14 11:39 PM
12/26/14 11:39 PM
Mattax
Phila. Pa.
I agree with Mr P Body - it depends It depends on whether there is enough area to begin with, whether the top is too close to the bowl vents, and the shape of the base.
My observation from stuff I've bought is that some drop bases have a very steep slope just inside the aircleaner. Others are a lot smoother.
Same with the tops. I was using a K&N filter top, but internally it was pinching the gap to the drop base. Externally, it was placing the retaining rod and nut very close to the hood. I switched to a nicely shaped spun aluminum top and picked up room both inside the aircleaner and hood clearance. So now I can run a taller cleaner or add 1/2" more carb spacer if I need.
Someplace I've seen a rough calculation of filter area for cfm, I just can't recall where right now.
[Re: ademon]
#1715128
12/27/14 01:07 AM
12/27/14 01:07 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
i don't know what to do with this! seems to rev fast to 6,500. but it has to be restrictive LOL.
Dude, the distributor is on the wrong end of the motor for a six pak to work well on All kidding aside the dual plane six pak intakes, both SB and BB limit the peak HP and torque RPM My sixpak 512 C.I. low deck pump gas stroker made peak torque at 4500 RPM and peak HP at 5500 RPM, but that stupid car would run faster shifting it at or above 7000 RPM in 1st and 2nd gear and cross the finish line between 6300 and 7000 RPM depending on the track elevation, local weather and rear tire size I learned a long time ago to shift the car when it quit pulling hard in each gear
[Re: mopar65]
#1715129
12/27/14 01:13 AM
12/27/14 01:13 AM
ProSport
Akron, Ohio
I need to find a set up for my tunnel ram that will fit under a 7 inch tall hood scoop.
I used a couple 9" air cleaners on mine, but I think my scoop was a 9".
[Re: AndyF]
#1715131
12/27/14 07:58 PM
12/27/14 07:58 PM
Thigh-Gap Junction
A 410 inch engine at 7500 rpm would need a 14x4 air filter. A 500 inch engine at 7500 rpm needs a 14x5 filter. I've used 14x5 and 14x6 filters on the dyno with 500 inches and a 1250 Dominator and there is no restriction. But it is hard to fit that large of a filter under a hood unless you use an extra tall 6 pack style.
Well, I don't rev my 500 to 7500, at least not intentionally My Wix Racing 16x3.5 equates to a 14x4 and shows no restriction to 7000 but I expect the Wix racing media flows better than the K&N. Going to a 16" filter helps overcome some of the geometric difficulties of a close carb-to-hood space, especially with a Dominator. I'd been wanting to delete the scoop for years and finally got around to it last winter. Still have to paint the hood to match the rest of the car. No loss in performance shows tall isn't necessary, just the easiest route.
For anyone who wants to browse the Wix Racing catalog: http://www.wixfilters.com/Speciality/Racing.aspx?1
[Re: AndyF]
#1715132
12/27/14 08:08 PM
12/27/14 08:08 PM
MR_P_BODY
What air temps did you test at... as the temps go up the flow goes down... but what you show is good to know
[Re: Thumperdart]
#1715134
12/27/14 08:21 PM
12/27/14 08:21 PM
MR_P_BODY
I'm not real happy with the filter I will have to run on my Rampage.. I checked it today and I'm gonna have to drop to a 2 3/4" filter.. might get a 3" in there.. I might take it off for racing
[Re: rebel]
#1715137
12/27/14 09:29 PM
12/27/14 09:29 PM
MR_P_BODY
next test was to just place my drop base over the duct & redo the test. straight away the peak value jumped up. so sorry to say Mr P. drop bases actually straighten the air & improve airflow.
I/m glad to see your testing.. but that wasnt what I seen on the filter flow bench at work... but its good to see your testing... by the way I tested with a lid on it with a filter... what your pulling is direct and the inner radius helps flow as you see... thats why I run a stack or as its called.. a ideal entry
[Re: MR_P_BODY]
#1715138
12/27/14 10:24 PM
12/27/14 10:24 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I used an 11"x5" K&N assembly with the velocity stack style base. Fit inside my Harwood snorkel with an isolator plate. My scoop is mounted on the engine and stays on the car when the hood is removed. Made a difference in the looks of the cylinder walls at the end of the year. And I don't worry about rocks and junk getting thrown into the scoop. Wouldn't be with out it now.
[Re: Thumperdart]
#1715139
12/28/14 12:07 AM
12/28/14 12:07 AM
Thigh-Gap Junction
Are you saying you run your air cleaner pokin through the hood? I`ve seen some 8-second cars w/no more than the air filter up in the wind.............
No scoop, no hole, 'glass copy of the factory '68 Barracuda hood with the pot metal inserts as well. Picture and description in my second post above somewhere...
[Re: @#$%&*!]
#1715140
12/28/14 02:01 AM
12/28/14 02:01 AM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
What I really really want is someone to make a drop dominator base that would use the Mopar oval lid, K&N makes a I think 3" tall I would have to check I cant recall Mopar oval air filter. I have that filter and a brand new "572 Hemi" factory style decaled lid sitting on a shelf waiting for such a magical base or for me to have one fabricated....
Anyone know of such a thing?
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: moparjimbo]
#1715141
12/29/14 02:25 AM
12/29/14 02:25 AM
rebel
aotearoa
i had a couple of PM's asking me if i did a test with the filter in place, i hadn't but i have now. so this test is with my Fram Air Hogg filter, freshly cleaned with an el cheapo chrome lid, as the test showed, it's still better than no filter plate at all.
[Re: rebel]
#1715144
12/29/14 03:05 AM
12/29/14 03:05 AM
MR_P_BODY
I like your numbers... how tall is your test filter... also I tested the K&N but your filter looks much nicer
[Re: Thumperdart]
#1715147
12/29/14 04:05 AM
12/29/14 04:05 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I'm leaning towards the uni filter as it's shape will be perfect for my hood. I always ran with out a filter because i felt a difference in my 93 dakota when racing with filter on or off. Also the truck pulled more rpm than it would with the filter on. But I'm pretty sure the stock hood played a major role in that the filter was most likely against the hood reducing air flow.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: rebel]
#1715148
12/29/14 11:36 AM
12/29/14 11:36 AM
MR_P_BODY
it's a 4" Mr P. i have a 3" K&N but it's MIA in the garage somewhere. i wanted to give that a clean too & compare but i only have (had?) the round element part.
Yeah I ran a 3" K&N... I was curious why you got different number.. I also forgot what flow I did this at but I believe it was a fair bit higher... wish I still had my paper work
[Re: Thumperdart]
#1715153
12/30/14 02:06 PM
12/30/14 02:06 PM
MR_P_BODY
I have to use a spacer for the air cleaner to clear the linkage and yesterday I seen that the front of the 14" dia filter hits the hood and holds it up a little... I'm gonna try angle cutting the spacer to see if that will clear... I dont want to go any shorter than the 3" filter that I am using... this is on my throttle body.. but it was about the same on the 850 carb.. but that was a bit lower(no spacer) EDIT Plus I'm dumping the K&N that was a gift to me.. but I need the flow
[Re: Thumperdart]
#1715155
12/30/14 02:39 PM
12/30/14 02:39 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I had been running a cheap 14x3 auto parts store filter for the past few years..... Just installed a new WIX Racing filter. My setup is a RamAirBox breathing through the grille. Wish I could fit a taller filter, but 3" with a drop base has me right against the hood.
[Re: Thumperdart]
#1715157
12/30/14 02:47 PM
12/30/14 02:47 PM
StealthWedge67
Puyallup, WA
Litrally just recieved it from Summit yesterday and istalled in last night. Doubt I'll FEEL any difference, but I'll be watching the timeslip! No, I don't have a wideband. It's on my priority list, though; Might even get one this winter (???).
[Re: StealthWedge67]
#1715159
12/30/14 03:30 PM
12/30/14 03:30 PM
MR_P_BODY
I really like those Ram type boxes with the hoses.. I'm trying to set something up like that with my cowl hood
[Re: MR_P_BODY]
#1715161
12/31/14 12:22 AM
12/31/14 12:22 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
My RW dyno results with a single carb on the Modman Carb was a 800cfm AVS THUNDER KN 14x3 with Xtreme lid - 318 RWHP MOROSO 16x3 - same day - 333 RWHP No air cleaner - 277 RWHP KN Hemi dual quad 2" high - twin AFB 500s - 358 RWHP Two lessons Ive learned over time... 1 - Carters hate being run without an air bell or cleaner. 2 - Xtreme lids rob HP compared to a decent size normal filter element. Joe Sherman has made similar findings on Speed Torque.
[Re: mopar65]
#1715163
12/31/14 12:51 AM
12/31/14 12:51 AM
Moparmal
If you go to K&Ns web site they have many different shapes of filters. You may have to get creative to build the base, but lids are easy to make out of aluminum plate should you need every last bit of room. For my race motor with a Dominater flange I used a drop base attached to an air pan combined with a 14x6 and a flat lid to get it under my scoop.
thanks for the info. I was thinking about trying to use a air filter that is used with the six pack set up? think it would flow more air than 2 9 inch air filters? I have 2 K&N 9 inch air filters but they are 8 inches tall by them self. if i had a shop etc i8 would just run the carbs through the hood with the 8 inch tall filters.
No way no how..
A 2" high oval 6 pack filter had 121sq" of filter area. (60.75 citcumference x 2" height.)
Two 9x8s = 226.16sq" x 2 = 452sq" !!!!
[Re: Moparmal]
#1715166
12/31/14 09:37 AM
12/31/14 09:37 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Mal , good to see you still plugging away FWIW i have dynoed my 440 and have found less than 5 rwhp difference aircleaner to no air cleaner ., but i have seen 20/25 rwhp gain with my air box . With a six pack scoop i would never run filter free , see a few motors eat something they shouldnt on drag strips . I run a 14x3 k&n with filter top , with drop base attached to the air box which is heat resistant fibreglass sheet . Maybe a taller filter may help Nearly time for a new season to start Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Thumperdart]
#1715169
12/31/14 03:20 PM
12/31/14 03:20 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Good info thankxxx.............So my 14x3 has been killin me from day one and the K&N site sez the 14x3 flows under 700 cfm and the Wix racing 4" flows 1000+ so that`s my next purchace. My s$%^z gonna fly next time out.......... This is good info. I had to switch to a 3" K&N from a 4" (both 14" dia. with K&N Extreme lid) when I changed carbs to a Dominator. It looks like I likely was choking the carb/engine. The Wix racing site shows their 14" X 3.01" to flow 1000 + CFM and they offer them in 1/4" taller increments too! Thanks, Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Moparmal]
#1715170
12/31/14 04:51 PM
12/31/14 04:51 PM
Cab_Burge
Moparmal, don't forget we race cars with motors, not motors on dynos The reason I'm pointing this out is I saw 8 HP loss on two different motors on two different engines dynos at two different altitudes testing the K&N Extreme filter lids and eventually ended doing a at the track test back to back to back, A,B,A, in less than twenty minutes between each run and saw a .020 to .030 ET reduction(quicker) and .3 MPH increase on a 3x14 filter using the lid This was on a 440 powered Duster with a sixpak type scoop molded on it, the air cleaner lid was close to the top of the scoop, less than a fingers width at the rear It was not sealed to the scoop either some of this hot rodding and race stuff doesn't always make since, HUH Test, test and test some more to learn whar does work
[Re: Thumperdart]
#1715171
01/01/15 05:02 AM
01/01/15 05:02 AM
Moparmal
470 BB 7500 max.............
You need appx 164 sq" of filtering area.
A 14x3 wont do it
A 16x3 wont do it (150.75sq")
A 14 x 4" WILL work.....179 sq"r
A 14 x 3 with extreme lid will work also.... = 221 sq" of filtering area.
On the issue of filter tops...I agree people do their own trialling..
BUT... theres no point doing a back to back if the filter without the lid wont support the required flow..........
[Re: mopar dave]
#1715176
01/02/15 12:24 AM
01/02/15 12:24 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
http://www.r2cperformance.com/I like the idea behind these filters but I need to call them and ask about the base not having an "ideal entry" even though they sell a sub stack like product. Great information in this thread. I guess I'll save my velocity stacks for looks when the car is in the shop.
[Re: Crizila]
#1715183
01/02/15 12:53 PM
01/02/15 12:53 PM
MR_P_BODY
Lots of good info, except on the particulate size these different filter Mfg's are trying to keep out of your engine. Any of them can give you some awesome flow numbers if they are just trying to keep out - marbles.
Thats what all this is about... what micron is the filter
[Re: mopar dave]
#1715185
01/02/15 02:20 PM
01/02/15 02:20 PM
Jeremiah
Rogue River, OR
I have their air cleaner for 4150. looks like the bass has a very good entry the way it fits the venturi's. they also claim a better flowing filter than a K&N. nice people.
Dave if you have a chance can you snap a few pictures of your setup? I like their filters however the clear poly stuff is a little too "Spectre-esque" for my taste. If I could swing it I'd run a sprint car style air box on my tunnel ram under the scoop.
[Re: Jeremiah]
#1715190
01/03/15 02:57 AM
01/03/15 02:57 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
found some pics on ebay. same as what I have. 4 hole base also offered.
[Re: mopar dave]
#1715193
01/03/15 10:56 AM
01/03/15 10:56 AM
Posts: 2,926 A shed in England
Tig
A shed in England
Sorry to hijack, but does anyone have pics of motors using filters on tunnel rams and dominator carbs?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: quickd100]
#1715195
01/03/15 05:45 PM
01/03/15 05:45 PM
Posts: 22,696 Bitopia
jcc
Bitopia
That is interesting, and with numbers , any pics of the ram air system?
[Re: mopar dave]
#1715196
01/03/15 05:54 PM
01/03/15 05:54 PM
Posts: 506 Utah, USA
1964superstock
Utah, USA
here's the base I have.
Where can you but this air filter base? Manufacture name, part number?
[Re: Thumperdart]
#1715208
01/05/15 02:04 AM
01/05/15 02:04 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: BradH]
#1715210
01/05/15 03:02 PM
01/05/15 03:02 PM
BradH
Not sure if running a smaller (more restrictive) filter setup on the street, and switching out to something more of a "bird and rock catcher" screen only at the track, is a viable approach... or if that's simply fooling myself.
1. ... 'cuz I was hoping for a comment or two in response to my last paragraph.
2. Where can flow test results for the Wix racing filters found? All I've noticed is the parts listings on Summit, et al, simply say "flow 1000+ CFM"... but it's the same "spec" regardless of size.
[Re: Thumperdart]
#1715215
01/05/15 08:18 PM
01/05/15 08:18 PM
MR_P_BODY
Just came across this thread on another forum: http://forums.tccoa.com/showthread.php?t=15773
Even though it's from 2003, the data is still valid IMO and the preface by the poster on the test methodology is also interesting.
First off, THIS is the reason I joined Moparts and a select few sites because of valuable info like this post is getting not squabbling bs like grade school kids in the sand box..............I agree about the 1000+ cfm in different sizes and would like closer more accurate data than that. Think I`ll call em.............
I think if you call them your gonna get some bogus number.. IF they even know... you would be talking to a salesman... I agree.. I would have figured a larger difference from a 3" to 4"... something just doesnt sound right
[Re: AndyF]
#1715217
01/06/15 12:01 AM
01/06/15 12:01 AM
Moparmal
14x3 = 131.94sq" filtering area 14x4 = 175.92sq" The 14x3 has 3/4. (75%) of the surface area of the 14x4 Unless its made out of a different material, or is thicker...I cant see how the 14x4 only flows 5.4 %. more! 907/860 x 100/1 = 105.4%.
[Re: AndyF]
#1715219
01/06/15 12:35 AM
01/06/15 12:35 AM
jcc
Bitopia
What if the measurement/test was thru say 1000cfm carb or something else that gave an upper limit to the flow?
[Re: jcc]
#1715220
01/06/15 12:44 AM
01/06/15 12:44 AM
MR_P_BODY
If thats the case then a lot of the data might be invalid .. who is to say that choke point didnt hold back flow on some of the 3" stuff
[Re: Moparmal]
#1715222
01/06/15 11:49 AM
01/06/15 11:49 AM
BradH
If people want to use the K&N formula - then this s how u calculate the surface area of a round filter.
Its circumference x height - Plug in the diameter into this calculator and itll tell you the circ.
Then x by height -
http://www.csgnetwork.com/circle_sphere_area_calculator.html
David Vizard says you need to adjust the height of the filter to account for the top & bottom molding and edge effects. So, your 3" filter calc really should be more like 2-3/4" (or whatever a particular filter measures) when you're trying to come up w/ effective surface area.
Also, for those who question the data I found and posted from tests performed elsewhere, no problem. But if you feel the need to pi$$ on the results, you should probably dig up your own data or -- even better -- conduct your own tests to (in)validate it.
At least I took the time to try and find something more than just a bunch of opinions on the subject.
[Re: Thumperdart]
#1715224
01/06/15 02:24 PM
01/06/15 02:24 PM
BradH
..."what" you really need to eat a Snickers........"why" because you`re not yourself when you don`t........
I'll have to settle for a blueberry muffin and a large hot chocolate. It's a little snowy here today and the forecast for the rest of the week isn't showing much break in the temp, either.
[Re: AndyF]
#1715227
01/06/15 04:53 PM
01/06/15 04:53 PM
MR_P_BODY
Air filters are super expensive to test since it requires a giant flow bench. A 14x6 K&N probably flows 2000 cfm at a reasonable depression so it would require a monster flow bench to test. Not too many people have access to that type of equipment.
Thats the thing... when I was working I used a bench that had either a 20hp or it might have been a 35hp electric motor to drive the bench... I have no idea what it could move at max(air flow) but it sure did get noisy... it was either a 6" or 8" throat that we would mount the filter housing on(different fixtures) for all the different shapes and sizes
[Re: BradH]
#1715228
01/07/15 08:01 AM
01/07/15 08:01 AM
Moparmal
Then x by height -
Yes...the K&N site also says that some compensation for the lid and base lips along with the filter band needs to be taken into account - but the figures I provided are not too far off to be of use.
As far as pissing on your tables.....I'll be happy to refrain from plagueing this thread with basic Math any further......feel free to keep burning any books you dont agree with........
[Re: Moparmal]
#1715229
01/07/15 01:22 PM
01/07/15 01:22 PM
BradH
The "basic math" is knowing what the CFM capability of a given area of filter material is at a specified test pressure. Then you get to factor in all of the other constraints (choke points, capacity limitations, etc.) for the test equipment used when comparing the same amount of filter area across different brands / types. Questioning the results when inconsistencies between what you'd expect to see vs. actual results is reasonable and understood. Calling someone else's test data bogus when you yourself have nothing to show that proves otherwise is just pissin' on it. I don't burn books, but I put a lot less value in unverified opinions over quantifiable test data, even if the methodology may not be ideal. At least that's a starting point for refining the test approach, especially when those inconsistencies show up. G'day mate... and don't let the salties get ya'!
[Re: Moparmal]
#1715231
01/07/15 05:25 PM
01/07/15 05:25 PM
BradH
So now Im just struggling to see where I called your data bogus?
You specifically may not have, but your response triggered a defensive reaction by me where I felt the need to make a general comment about the way some others reacted to my posting of data.
Eh...
[Re: BradH]
#1715233
01/07/15 07:14 PM
01/07/15 07:14 PM
Moparmal
Eh...
Next time aim straight.......or eat two snickers......:p
Fwiw. I'm not making a call on that data table one way or the other.....too many unknowns.
[Re: AndyF]
#1715235
01/07/15 10:56 PM
01/07/15 10:56 PM
BradH
Andy - I don't disagree. That data I referenced didn't include all the necessary background to fully understand (as I phrased it above) "... all of the other constraints (choke points, capacity limitations, etc.) for the test equipment used when comparing the same amount of filter area across different brands / types."
For example, what if all those tests were based on how much air someone could pull through a 1.56" v x 1.75" throttle race-type 4150 that might dry-flow 925 CFM at the same test pressure? Then it wouldn't be a test of the max flow capabilities for each 3" vs. 4" filter element, and, instead, how many CFM each filter reduced the carb's peak flow capabilities.
Assuming EVERY filter is going to result in at least some amount of restriction, then the smaller delta between the 3" and 4" versions of the same filter types might be explained because the 4" filters aren't being tested to their limits, whereas some of the 3" might be getting right up to their full flow capabilities.
Regardless, my intent was simply to add more data, unfortunately w/o being able to explain the whole test setup.
[Re: Moparmal]
#1715236
01/07/15 10:59 PM
01/07/15 10:59 PM
BradH
Sawed-off 12-gauge shotguns aren't exactly known for pinpoint accuracy.
TWO Snickers??? Gawd, my blood sugar level would go into ; besides, I like Milky Ways better.
[Re: BradH]
#1715238
01/07/15 11:29 PM
01/07/15 11:29 PM
Moparmal
Sawed-off 12-gauge shotguns aren't exactly known for pinpoint accuracy. :
Yeah...but they talk louder to a crowd......
[Re: Thumperdart]
#1715239
01/07/15 11:36 PM
01/07/15 11:36 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I've been sitting back and following this thread. Really don't have much to add other than my set up. Y'all talkin over my head with the flow stuff Never did make a pass without the filter. Don't know why, just figured there were other area's of the car that needed more attention It is on the "To Do" list if I can ever get back out 14 x 5 K&N with the Extreme top snuggled in an Aero scoop. I figured it should flow enough and send less turbulent air to the carb
[Re: Moparmal]
#1715242
01/07/15 11:48 PM
01/07/15 11:48 PM
Posts: 148 Montgomery, PA
dodge340dart
Montgomery, PA
Here are some results I have found on a slant six (I know not a race engine) but they are interesting. All tests were on a Mustang Chassis Dyno.
With the 1-bbl (1920 Holley) carburetor: factory OEM filter in factory air cleaner housing Max Torque : 132.558lb-ft Max Horsepower: 83.177hp Avg Torque : 122.779lb-ft Avg Horsepower: 76.279hp
K&N filter in factory air cleaner housing Max Torque : 134.171lb-ft Max Horsepower: 83.767hp Avg Torque : 122.590lb-ft Avg Horsepower: 79.365hp
Improvement over baseline Max Torque: 1.583lb-ft Max Horsepower: 0.590hp Avg Torque: (-0.189)lb-ft Avg Horsepower: 3.086hp
Baseplate only (no filter) Max Torque : 132.827lb-ft Max Horsepower: 84.484hp Avg Torque : 122.213lb-ft Avg Horsepower: 79.088hp
Improvement over baseline Max Torque: 0.269b-ft Max Horsepower: 1.307hp Avg Torque: (-0.566)lb-ft Avg Horsepower: 2.809hp
I will get the data together for the 2-bbl and the 4-bbl carbs/filters and post it as well.
Chris
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion
2012 BSD Friday Street Racer Driver of the Year
3-time Jr. Stock Eliminator
2-time Mean Street Eliminator
'69 340 Dart 1.500 60ft, 11.359et, 117.08mph
[Re: dodge340dart]
#1715243
01/07/15 11:56 PM
01/07/15 11:56 PM
dodge340dart
Montgomery, PA
Here are the results from the slant six on the Mustang Chassis Dyno.
These results are with a 2-bbl (Carter BBD) factory air filter and Super-Six air cleaner housing Max Torque : 140.414lb-ft Max Horsepower: 93.337hp Avg Torque : 131.983lb-ft Avg Horsepower: 88.101hp
K&N air filter and Super-Six air cleaner housing Max Torque : 142.708lb-ft Max Horsepower: 95.763hp Avg Torque : 135.147lb-ft Avg Horsepower: 90.406hp
Baseplate only Max Torque : 150.937lb-ft Max Horsepower: 103.493hp Avg Torque : 143.384lb-ft Avg Horsepower: 96.418hp
Let me find the 4bbl data on the same slant.
Chris
[Re: dodge340dart]
#1715244
01/08/15 12:05 AM
01/08/15 12:05 AM
dodge340dart
Montgomery, PA
The slant six with a 390 Holley 4-bbl. 14"x2" open element filter/housing (WIX) Max Torque : 155.596lb-ft Max Horsepower: 113.730hp Avg Torque : 150.006lb-ft Avg Horsepower: 103.531hp 14"x3" open element filter/housing (WIX) Max Torque : 156.068lb-ft Max Horsepower: 113.584hp Avg Torque : 150.271lb-ft Avg Horsepower: 103.686hp 14"x3" open element filter/housing (K&N) Max Torque : 154.269lb-ft Max Horsepower: 112.463hp Avg Torque : 148.416lb-ft Avg Horsepower: 102.434hp 14" baseplate only Max Torque : 158.393lb-ft Max Horsepower: 115.839hp Avg Torque : 152.777lb-ft Avg Horsepower: 105.826hp A run from the above test: https://www.youtube.com/watch?v=IlkXawoGFLoChris
[Re: dodge340dart]
#1715245
01/08/15 12:21 AM
01/08/15 12:21 AM
MR_P_BODY
On all 3 engine set ups it was just the filter change, no jet work.. am I correct.. were you running a A/F meter
[Re: dodge340dart]
#1715246
01/08/15 12:27 AM
01/08/15 12:27 AM
jcc
Bitopia
The heck with the filters, I'm getting a 390 Holley for my slant six Thanks for the info Back to the confusing chart, I think it was made with a carb or other restriction (only logical explanation with the data we have), and that in some cases makes some sense, because for instance, whats the point of doubling(?) a filter's area, if the gain is very small because of the limits of the carb? Besides everyone pretty much agrees we already know doubling a filters area (same), will double airflow.
[Re: MR_P_BODY]
#1715247
01/08/15 12:31 AM
01/08/15 12:31 AM
dodge340dart
Montgomery, PA
You are correct, there were no changes other than changing the air filter element. I don't have the A/F numbers with me, they are at the office, but they were monitored on each run. I remember that the numbers leaned out just a little from the first test of each series to the baseplate only runs. If I remember the runs ranged from about 12.3:1 to 12.85:1 as the runs progressed. I will have to see if I can dig up the numbers tomorrow.
Chris
[Re: dodge340dart]
#1715248
01/08/15 12:50 AM
01/08/15 12:50 AM
MR_P_BODY
Chris
The A/F numbers are as I would expect
[Re: Crizila]
#1715251
01/08/15 02:45 PM
01/08/15 02:45 PM
roadhazard
Akron, Ohio U.S.A.
K&N Stub Stack holds the base to the carb
Really nice set up.
I have some 4779-2 blocks but it's sooooo cold here I'm afraid to pick up a wrench
