Page 9 of 10 1 2 7 8 9 10
Re: Air filters on race cars?? [Re: BradH] #1715225
01/06/15 02:34 PM
01/06/15 02:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m eating oatmeal in a tee shirt on the patio...........
Re: Air filters on race cars?? [Re: BradH] #1715226
01/06/15 04:14 PM
01/06/15 04:14 PM
AndyF Online content
AndyF  Online Content
Air filters are super expensive to test since it requires a giant flow bench. A 14x6 K&N probably flows 2000 cfm at a reasonable depression so it would require a monster flow bench to test. Not too many people have access to that type of equipment.
Re: Air filters on race cars?? [Re: AndyF] #1715227
01/06/15 04:53 PM
01/06/15 04:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the thing... when I was working I used a bench
that had either a 20hp or it might have been a 35hp
electric motor to drive the bench... I have no idea
what it could move at max(air flow) but it sure did
get noisy... it was either a 6" or 8" throat that
we would mount the filter housing on(different fixtures)
for all the different shapes and sizes
Re: Air filters on race cars?? [Re: BradH] #1715228
01/07/15 08:01 AM
01/07/15 08:01 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
If people want to use the K&N formula - then this s how u calculate the surface area of a round filter.
Its circumference x height - Plug in the diameter into this calculator and itll tell you the circ.
Then x by height -
http://www.csgnetwork.com/circle_sphere_area_calculator.html
David Vizard says you need to adjust the height of the filter to account for the top & bottom molding and edge effects. So, your 3" filter calc really should be more like 2-3/4" (or whatever a particular filter measures) when you're trying to come up w/ effective surface area.
Also, for those who question the data I found and posted from tests performed elsewhere, no problem. But if you feel the need to pi$$ on the results, you should probably dig up your own data or -- even better -- conduct your own tests to (in)validate it.
At least I took the time to try and find something more than just a bunch of opinions on the subject.
Yes...the K&N site also says that some compensation for the lid and base lips along with the filter band needs to be taken into account - but the figures I provided are not too far off to be of use.
As far as pissing on your tables.....I'll be happy to refrain from plagueing this thread with basic Math any further......feel free to keep burning any books you dont agree with........
Re: Air filters on race cars?? [Re: Moparmal] #1715229
01/07/15 01:22 PM
01/07/15 01:22 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The "basic math" is knowing what the CFM capability of a given area of filter material is at a specified test pressure.
Then you get to factor in all of the other constraints (choke points, capacity limitations, etc.) for the test equipment used when comparing the same amount of filter area across different brands / types.
Questioning the results when inconsistencies between what you'd expect to see vs. actual results is reasonable and understood. Calling someone else's test data bogus when you yourself have nothing to show that proves otherwise is just pissin' on it.
I don't burn books, but I put a lot less value in unverified opinions over quantifiable test data, even if the methodology may not be ideal. At least that's a starting point for refining the test approach, especially when those inconsistencies show up.
G'day mate... and don't let the salties get ya'!
Re: Air filters on race cars?? [Re: BradH] #1715230
01/07/15 05:06 PM
01/07/15 05:06 PM
Moparmal Offline
Moparmal  Offline
So now Im just struggling to see where I called your data bogus?
Re: Air filters on race cars?? [Re: Moparmal] #1715231
01/07/15 05:25 PM
01/07/15 05:25 PM
BradH Offline
BradH  Offline
You specifically may not have, but your response triggered a defensive reaction by me where I felt the need to make a general comment about the way some others reacted to my posting of data.
Eh...
Re: Air filters on race cars?? [Re: Moparmal] #1715232
01/07/15 05:38 PM
01/07/15 05:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
He is referring to what I wrote..." COULD BE bogus"
based on what you mentioned .. but since we dont know
how the test was performed its just a speculation
Re: Air filters on race cars?? [Re: BradH] #1715233
01/07/15 07:14 PM
01/07/15 07:14 PM
Moparmal Offline
Moparmal  Offline
Eh...
Next time aim straight.......or eat two snickers......:p
Fwiw. I'm not making a call on that data table one way or the other.....too many unknowns.
Re: Air filters on race cars?? [Re: BradH] #1715234
01/07/15 10:08 PM
01/07/15 10:08 PM
I appreciate the fact that you took the time to find some data and post it. That is cool and it is way more than a lot of people do in these threads. However, I will say that the 4" data doesn't make much sense when compared to the 3" data. The 4" flow rates should be 33% greater than the 3" flow rates. More than 33% if you take into account the edge effect.
Based on other numbers I've seen I think the 4" data in the table is wrong. A 14x4 filter should flow around 1200 cfm. Of course, flow depends on pressure drop so to be precise someone needs to say what pressure drop they are willing to live with and then measure flow at that drop. I don't know what K&N uses as a std pressure drop for filter testing but it is probably fairly low.
Re: Air filters on race cars?? [Re: AndyF] #1715235
01/07/15 10:56 PM
01/07/15 10:56 PM
BradH Offline
BradH  Offline
Andy - I don't disagree. That data I referenced didn't include all the necessary background to fully understand (as I phrased it above) "... all of the other constraints (choke points, capacity limitations, etc.) for the test equipment used when comparing the same amount of filter area across different brands / types."
For example, what if all those tests were based on how much air someone could pull through a 1.56" v x 1.75" throttle race-type 4150 that might dry-flow 925 CFM at the same test pressure? Then it wouldn't be a test of the max flow capabilities for each 3" vs. 4" filter element, and, instead, how many CFM each filter reduced the carb's peak flow capabilities.
Assuming EVERY filter is going to result in at least some amount of restriction, then the smaller delta between the 3" and 4" versions of the same filter types might be explained because the 4" filters aren't being tested to their limits, whereas some of the 3" might be getting right up to their full flow capabilities.
Regardless, my intent was simply to add more data, unfortunately w/o being able to explain the whole test setup.
Re: Air filters on race cars?? [Re: Moparmal] #1715236
01/07/15 10:59 PM
01/07/15 10:59 PM
BradH Offline
BradH  Offline
Sawed-off 12-gauge shotguns aren't exactly known for pinpoint accuracy.
TWO Snickers??? Gawd, my blood sugar level would go into ; besides, I like Milky Ways better.
Re: Air filters on race cars?? [Re: BradH] #1715237
01/07/15 11:03 PM
01/07/15 11:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Go play your drums damit. I`m off now to go , , , and trust me, it helps a LOT in the aggression dept. after 4 hours of bashin although we play a few ballads......
Re: Air filters on race cars?? [Re: BradH] #1715238
01/07/15 11:29 PM
01/07/15 11:29 PM
Moparmal Offline
Moparmal  Offline
Sawed-off 12-gauge shotguns aren't exactly known for pinpoint accuracy. :
Yeah...but they talk louder to a crowd......
Re: Air filters on race cars?? [Re: Thumperdart] #1715239
01/07/15 11:36 PM
01/07/15 11:36 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I've been sitting back and following this thread. Really don't have much to add other than my set up.
Y'all talkin over my head with the flow stuff
Never did make a pass without the filter. Don't know why, just figured there were other area's of the car that needed more attention
It is on the "To Do" list if I can ever get back out
14 x 5 K&N with the Extreme top snuggled in an Aero scoop.
I figured it should flow enough and send less turbulent air to the carb
Re: Air filters on race cars?? [Re: roadhazard] #1715240
01/07/15 11:39 PM
01/07/15 11:39 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Home made base seals to bottom of hood....
Re: Air filters on race cars?? [Re: roadhazard] #1715241
01/07/15 11:41 PM
01/07/15 11:41 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
K&N Stub Stack holds the base to the carb
Re: Air filters on race cars?? [Re: Moparmal] #1715242
01/07/15 11:48 PM
01/07/15 11:48 PM
Montgomery, PA
dodge340dart Offline
Montgomery, PA
Here are some results I have found on a slant six (I know not a race engine) but they are interesting. All tests were on a Mustang Chassis Dyno.
With the 1-bbl (1920 Holley) carburetor:
factory OEM filter in factory air cleaner housing
Max Torque : 132.558lb-ft
Max Horsepower: 83.177hp
Avg Torque : 122.779lb-ft
Avg Horsepower: 76.279hp
K&N filter in factory air cleaner housing
Max Torque : 134.171lb-ft
Max Horsepower: 83.767hp
Avg Torque : 122.590lb-ft
Avg Horsepower: 79.365hp
Improvement over baseline
Max Torque: 1.583lb-ft
Max Horsepower: 0.590hp
Avg Torque: (-0.189)lb-ft
Avg Horsepower: 3.086hp
Baseplate only (no filter)
Max Torque : 132.827lb-ft
Max Horsepower: 84.484hp
Avg Torque : 122.213lb-ft
Avg Horsepower: 79.088hp
Max Torque: 0.269b-ft
Max Horsepower: 1.307hp
Avg Torque: (-0.566)lb-ft
Avg Horsepower: 2.809hp
I will get the data together for the 2-bbl and the 4-bbl carbs/filters and post it as well.
Chris
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion 2012 BSD Friday Street Racer Driver of the Year 3-time Jr. Stock Eliminator 2-time Mean Street Eliminator '69 340 Dart 1.500 60ft, 11.359et, 117.08mph
Re: Air filters on race cars?? [Re: dodge340dart] #1715243
01/07/15 11:56 PM
01/07/15 11:56 PM
Montgomery, PA
Montgomery, PA
Here are the results from the slant six on the Mustang Chassis Dyno.
These results are with a 2-bbl (Carter BBD)
factory air filter and Super-Six air cleaner housing
Max Torque : 140.414lb-ft
Max Horsepower: 93.337hp
Avg Torque : 131.983lb-ft
Avg Horsepower: 88.101hp
K&N air filter and Super-Six air cleaner housing
Max Torque : 142.708lb-ft
Max Horsepower: 95.763hp
Avg Torque : 135.147lb-ft
Avg Horsepower: 90.406hp
Baseplate only
Max Torque : 150.937lb-ft
Max Horsepower: 103.493hp
Avg Torque : 143.384lb-ft
Avg Horsepower: 96.418hp
Let me find the 4bbl data on the same slant.
Chris
Re: Air filters on race cars?? [Re: dodge340dart] #1715244
01/08/15 12:05 AM
01/08/15 12:05 AM
Montgomery, PA
Montgomery, PA
The slant six with a 390 Holley 4-bbl.
14"x2" open element filter/housing (WIX)
Max Torque : 155.596lb-ft
Max Horsepower: 113.730hp
Avg Torque : 150.006lb-ft
Avg Horsepower: 103.531hp
14"x3" open element filter/housing (WIX)
Max Torque : 156.068lb-ft
Max Horsepower: 113.584hp
Avg Torque : 150.271lb-ft
Avg Horsepower: 103.686hp
14"x3" open element filter/housing (K&N)
Max Torque : 154.269lb-ft
Max Horsepower: 112.463hp
Avg Torque : 148.416lb-ft
Avg Horsepower: 102.434hp
14" baseplate only
Max Torque : 158.393lb-ft
Max Horsepower: 115.839hp
Avg Torque : 152.777lb-ft
Avg Horsepower: 105.826hp
A run from the above test: https://www.youtube.com/watch?v=IlkXawoGFLo
Chris
