Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: Air filters on race cars?? [Re: Thumperdart] #1715165
12/31/14 04:29 AM
12/31/14 04:29 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
What cubes and peak rpm do you run?
Re: Air filters on race cars?? [Re: Moparmal] #1715166
12/31/14 09:37 AM
12/31/14 09:37 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Mal , good to see you still plugging away
FWIW i have dynoed my 440 and have found less than 5 rwhp difference aircleaner to no air cleaner ., but i have seen 20/25 rwhp gain with my air box . With a six pack scoop i would never run filter free , see a few motors eat something they shouldnt on drag strips .
I run a 14x3 k&n with filter top , with drop base attached to the air box which is heat resistant fibreglass sheet . Maybe a taller filter may help
Nearly time for a new season to start
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Air filters on race cars?? [Re: Moparmal] #1715167
12/31/14 01:26 PM
12/31/14 01:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
470 BB 7500 max.............
Re: Air filters on race cars?? [Re: Moparmal] #1715168
12/31/14 02:28 PM
12/31/14 02:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My RW dyno results with a single carb on the
Modman
Carb was a 800cfm AVS THUNDER
KN 14x3 with Xtreme lid - 318 RWHP
MOROSO 16x3 - same day - 333 RWHP
No air cleaner - 277 RWHP
KN Hemi dual quad 2" high - twin AFB 500s - 358 RWHP
Two lessons Ive learned over time...
1 - Carters hate being run without an air bell or cleaner.
2 - Xtreme lids rob HP compared to a decent size normal filter element. Joe Sherman has made similar findings on Speed Torque.
Your conclusion maybe correct, or there just might a significant difference in the restriction of a K&N vs a Moroso element besides basic area, or the amount of oiling, etc.
I believe most agree on the basic facts, its the conclusions from those facts where we differ.
Re: Air filters on race cars?? [Re: Thumperdart] #1715169
12/31/14 03:20 PM
12/31/14 03:20 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Good info thankxxx.............So my 14x3 has been killin me from day one and the K&N site sez the 14x3 flows under 700 cfm and the Wix racing 4" flows 1000+ so that`s my next purchace. My s$%^z gonna fly next time out..........
This is good info. I had to switch to a 3" K&N from a 4" (both 14" dia. with K&N Extreme lid) when I changed carbs to a Dominator. It looks like I likely was choking the carb/engine.
The Wix racing site shows their 14" X 3.01" to flow 1000 + CFM and they offer them in 1/4" taller increments too!
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Air filters on race cars?? [Re: Moparmal] #1715170
12/31/14 04:51 PM
12/31/14 04:51 PM
Moparmal, don't forget we race cars with motors, not motors on dynos The reason I'm pointing this out is I saw 8 HP loss on two different motors on two different engines dynos at two different altitudes testing the K&N Extreme filter lids and eventually ended doing a at the track test back to back to back, A,B,A, in less than twenty minutes between each run and saw a .020 to .030 ET reduction(quicker) and .3 MPH increase on a 3x14 filter using the lid This was on a 440 powered Duster with a sixpak type scoop molded on it, the air cleaner lid was close to the top of the scoop, less than a fingers width at the rear It was not sealed to the scoop either some of this hot rodding and race stuff doesn't always make since, HUH Test, test and test some more to learn whar does work
Re: Air filters on race cars?? [Re: Thumperdart] #1715171
01/01/15 05:02 AM
01/01/15 05:02 AM
Moparmal Offline
Moparmal  Offline
You need appx 164 sq" of filtering area.
A 14x3 wont do it
A 16x3 wont do it (150.75sq")
A 14 x 4" WILL work.....179 sq"r
A 14 x 3 with extreme lid will work also.... = 221 sq" of filtering area.
On the issue of filter tops...I agree people do their own trialling..
BUT... theres no point doing a back to back if the filter without the lid wont support the required flow..........
Re: Air filters on race cars?? [Re: Moparmal] #1715172
01/01/15 12:59 PM
01/01/15 12:59 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
This is all good info.I'm putting my car back on the street and I'll need to use a air cleaner. Just bought some 14x3 Fram Air Hog filters at Rock Auto for less than $5.00 a filter.
Nautilus Racing-
Re: Air filters on race cars?? [Re: Chris2581] #1715173
01/01/15 01:50 PM
01/01/15 01:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Here's my 10x2.75 filter on my 500" engine, if I ever make it to a track the filter will be coming off lol. I run an A-body dual snorkel factory scoop.
Re: Air filters on race cars?? [Re: ProSport] #1715174
01/01/15 02:44 PM
01/01/15 02:44 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I WANT to run a filter even at the track, but the better intake manifold I'd like to use is taller than the one that I can actually fit under my T/A hood scoop and won't allow for an adequately sized filter.
Not sure if running a smaller (more restrictive) filter setup on the street, and switching out to something more of a "bird and rock catcher" screen only at the track, is a viable approach... or if that's simply fooling myself.
Re: Air filters on race cars?? [Re: Thumperdart] #1715175
01/01/15 03:12 PM
01/01/15 03:12 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
didn't know the wix was that good. I guess i'll keep mine on there. I had planed on replacing it with a K&N,but i'll save my money. thanks Dom.
Re: Air filters on race cars?? [Re: mopar dave] #1715176
01/02/15 12:24 AM
01/02/15 12:24 AM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
http://www.r2cperformance.com/
I like the idea behind these filters but I need to call them and ask about the base not having an "ideal entry" even though they sell a sub stack like product.
Great information in this thread. I guess I'll save my velocity stacks for looks when the car is in the shop.
Re: Air filters on race cars?? [Re: Jeremiah] #1715177
01/02/15 02:12 AM
01/02/15 02:12 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have their air cleaner for 4150. looks like the bass has a very good entry the way it fits the venturi's. they also claim a better flowing filter than a K&N. nice people.
Re: Air filters on race cars?? [Re: mopar dave] #1715178
01/02/15 02:17 AM
01/02/15 02:17 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It just makes sense to me............If I drop the Wix on my car and the idle doesn`t change then we might be on to something.
Re: Air filters on race cars?? [Re: Jeremiah] #1715179
01/02/15 10:52 AM
01/02/15 10:52 AM
Mt. Eden Ky.
Mt. Eden Ky.
They claim 1600+ cfm for their 14" filters.
No prices that I could find though?
http://www.r2cperformance.com/14-inch-high-performance-street-air-filters.aspx
EDIT
I see that Summit has them.
Quite a spread on purpose and price!
http://www.summitracing.com/compare
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Air filters on race cars?? [Re: Hemi Allstate] #1715180
01/02/15 12:25 PM
01/02/15 12:25 PM
Az
Crizila Offline
Crizila  Offline
Az
EDIT
Mark
on the R2C sight.
Fastest 300
Re: Air filters on race cars?? [Re: Thumperdart] #1715181
01/02/15 12:35 PM
01/02/15 12:35 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
it worth a try. I found my wix air filter on ebay for next to nothing.
Re: Air filters on race cars?? [Re: mopar dave] #1715182
01/02/15 12:46 PM
01/02/15 12:46 PM
Az
Crizila Offline
Crizila  Offline
Az
Lots of good info, except on the particulate size these different filter Mfg's are trying to keep out of your engine. Any of them can give you some awesome flow numbers if they are just trying to keep out - marbles.
Fastest 300
Re: Air filters on race cars?? [Re: Crizila] #1715183
01/02/15 12:53 PM
01/02/15 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what all this is about... what micron is the filter
Re: Air filters on race cars?? [Re: MR_P_BODY] #1715184
01/02/15 02:12 PM
01/02/15 02:12 PM
Az
Crizila Offline
Crizila  Offline
Az
"It's a secret, only 3 women know".
Fastest 300
