Page 1 of 10 1 2 3 9 10
Air filters on race cars?? #1715065
12/24/14 09:20 PM
12/24/14 09:20 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
What are you guys using for air filters? I notice if I take mine off I can Rev above 9200 rpms. Is there a air cleaner that can handle high rpms and cfm?
Or do you just run without them?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Air filters on race cars?? [Re: DemonDust] #1715066
12/24/14 09:31 PM
12/24/14 09:31 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I tested with and without the air cleaner and the car ran the same in the 1/8. Mine is a big filter, 16x3 I believe.
Re: Air filters on race cars?? [Re: DemonDust] #1715067
12/24/14 09:55 PM
12/24/14 09:55 PM
AndyF Offline
AndyF  Offline
I use a K&N 14x6 air cleaner on the dyno. No power loss at 900+ hp. So if you have room for a big air filter then you should run one. Not only does it keep junk out of the engine but it can also help improve the air flow to the carb. An open hood scoop can have a lot of airflow over the carb which can disturb how the air goes into the carb. The air filter element slows down the air and helps it make the turn into the carb.
Re: Air filters on race cars?? [Re: DemonDust] #1715068
12/24/14 10:12 PM
12/24/14 10:12 PM
Az
Crizila Offline
Crizila  Offline
Az
Simply put, if you wanna run an air filter, find the biggest one that will fit your application. If your car runs better with one, you have turbulence / A/F mixture issues or the carb is too big - all of which should be corrected by other means than installing an air filter. No matter how you cut it, an air filter is a restriction.
Fastest 300
Re: Air filters on race cars?? [Re: DemonDust] #1715069
12/24/14 10:23 PM
12/24/14 10:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run a 3x14 but it`s a small loss in the 1/8 and it does richen up slightly at idle when tuned w/out it on............
Re: Air filters on race cars?? [Re: Thumperdart] #1715070
12/24/14 10:44 PM
12/24/14 10:44 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Never run one...
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Air filters on race cars?? [Re: D-50] #1715071
12/24/14 11:19 PM
12/24/14 11:19 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
our track unfortunately has some stones lifting off the seal on the return road & after seeing 1 racer get a stone flick up from their front wheel & lodge itself into carbs butterflies, i would never ever run without some kind of filtration on my carb. the car with the stone in the butterflies took off with front brakes locked on & plowed into another racecar before the owner could shut it off. not a happy day for 2 racers that day. i'm using Frams Airhogg air cleaner. it's pretty good, virtualy no difference with it on or off, but i now leave it on.
Re: Air filters on race cars?? [Re: DemonDust] #1715072
12/24/14 11:42 PM
12/24/14 11:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think if you double the diameter on your size air cleaner it will triple the air flow abiltiys of that size air cleaner. Try contacting K&N tech or go on thier web site for the formula on how to figure the total square area of thier filters Years ago I dyno tested two different K&N Extreme filter tops on two different 14 inch diameter air cleaners on two different dynos, both times the motors loss right at 8 HP I did a similar test at the track A,B,A test on the one of the same lids on a 14 inch K&N aircleaner on a 1050 Holley Dominator carb and the stupid dang car went a little quicker ET (.03 to .04)and faster (.3 and .25MPH) with the lid on, two times So I ended up leaving it on. I have dyno tested other air cleaners on other motors also, as you have found out to little will cost you HP and some times torque, not so on two big IHTHs EDITED, I don't race without a decent filter now, especially as I get older and don't like reringing motors sooner than I could by using a decent air filter
Re: Air filters on race cars?? [Re: Cab_Burge] #1715073
12/24/14 11:56 PM
12/24/14 11:56 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I don't use one
Re: Air filters on race cars?? [Re: SpareParts] #1715074
12/25/14 01:40 AM
12/25/14 01:40 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Speaker grill
Re: Air filters on race cars?? [Re: sixpackgut] #1715075
12/25/14 01:48 AM
12/25/14 01:48 AM
gregsdart Offline
gregsdart  Offline
The K & N web site has the formula for square inches of filter to hp for no loss. If I recall it is 7 hp for each square inch of filter using the K&N type. I bought a 6 x 14 for next year. I learned the hard way it is impossible for the most part to aviod getting some dirt in the motor. When I saw the dirt film in the throttle body that did it for me.
Re: Air filters on race cars?? [Re: gregsdart] #1715076
12/25/14 03:31 AM
12/25/14 03:31 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Yep......K&N makes some nice stuff and bigger is better here for sure.
Re: Air filters on race cars?? [Re: Bigcube] #1715077
12/25/14 10:10 AM
12/25/14 10:10 AM
Menomonee Falls
Menomonee Falls
Thanks for all the info guys!
Merry Christmas!
SDG Motorsports
Re: Air filters on race cars?? [Re: rebel] #1715078
12/25/14 11:22 AM
12/25/14 11:22 AM
Az
Crizila Offline
Crizila  Offline
Az
and if you are going to use a "conventional" round style air filter, get one with a breathable top. Just that much more area that is seldom used.
Fastest 300
Re: Air filters on race cars?? [Re: Crizila] #1715079
12/25/14 11:51 AM
12/25/14 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I found the top lid causes issues on flow... you get
2 different air paths that crash into each other
and in the end you get less into the carb... I also
see that its worse if you have a drop base because
the air is going up first then has to turn down to
get into the carb.. but the side air is plowing into
the lid air ... on the track I dont run a air cleaner
Re: Air filters on race cars?? [Re: MR_P_BODY] #1715080
12/25/14 12:41 PM
12/25/14 12:41 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I wouldn't run without one. Rocks and sand are a killer. Big K&N under the scoop.
Re: Air filters on race cars?? [Re: camastomcat] #1715081
12/25/14 12:47 PM
12/25/14 12:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was gonna try to make a lite filter for the inlet
of my scoop but never got around to it.. I cant put
one in the scoop... but basically it would stop sticks
and rocks
Re: Air filters on race cars?? [Re: DemonDust] #1715082
12/25/14 01:04 PM
12/25/14 01:04 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
here's what I use on a dominator. its a moroso 16x3. I painted the lid and put a 4" in it.
Re: Air filters on race cars?? [Re: mopar dave] #1715083
12/25/14 01:15 PM
12/25/14 01:15 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I remember a few years ago this came up and everybody was talking about how they use one of those filters that looks like a flat box with a wedge in the front all the air came in the top/front. Don't remember the name. I remember looking them up since I was looking for a better option under my 340 scoop. Too much $$ for my street effort.
Edit: looked it up on google image- 'UNI' filter
Re: Air filters on race cars?? [Re: mopar dave] #1715084
12/25/14 01:16 PM
12/25/14 01:16 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Had a big block chevy on the dyno, tuned it for max power, THEN the owner mentions he runs an air cleaner and it’s in the truck. We put it on and the engine loss 26 HP, then lean the carb back down and gained 28 HP.
Joe
Without Data, you’re just another guy with an opinion.
