Quote: dont even consider a 1971 engine unless its been rebuilt with some aftermarket pistons in the past. i have one and the piston deck height is .090 .
The 1971 383 (four barrel) I have has stock flat top pistons, no valve reliefs, 0.020 in the hole. The block is stamped 1970. Came out of a 1971 Newport.
2010 Black Challenger SE <> 3.5 V6 Custom Shift Knobs www.flameball.com Check It Out
