Quote: Assuming a race weight of 3850, 10.50 ETs need 657 hp. Lets say you settle on a figure of 680 hp as what you want so you have a little margin. You can do that with a stroked big block with a set of ported SR heads.
I ran the MW Indy EZs done by jeff at MCH... would have ran better with more tuning and cool weather also.... was a small solid roller with 248/254@50 .650 lift range...
