Red Sled, you have a PM
I'd love to hear some details about the times run with the Weiand tunnel ram. I tried this unit, and had some trouble with a bog (using stock style 6-pack carbs). I ran it on a 3700 pound Road Runner with 4.30 gears, a 3800RPM converter, and a modified stock motor with a .575 Comp roller cam. It was modified per the Mopar Engine book. It ran great once it got over a bog between the idle and secondary metering systems. Have you guys had this same issue? Were your set-ups anywhere near the ones mentioned in the book? Tom
