Without seeing the numbers on the carbs, I call them Ford carbs because that is the configuration that Ford ran in STOCK 3x2 form - fuel inlets on the linkage side, mechanical linkage, and accel pumps in ind carbs. Mopar carbs in STOCK form had vacuum pods (and no accel pumps)on the end carbs, and the fuel inlets on the pod sides. I guess I should have known to say Ford TYPE or Mopar TYPE to eliminate the nit-picking and hair spliting.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
