If your spring is compressing, I'd aim your efforts there.
Let's assume the spring is weak or there is too much resistance in the squirter circuit. Switching to a hollow shooter screw AND/OR shimming the spring will help.
Unlike bigger jets and bigger shooters. This modification will not consume more fuel.
