Won't be a secondary problem , if the secs are coming in too late it would't buck , just the opposite.............have you looked @ pump arm adjustment? , maybe turn the mixture screws out a tad & go try it.........................with the car idleing tap the pump shooter & if the motor picks up it's too lean , if the motor slows down it's usually to rich...........could also be a transition issue.
