Since your are running the highest octane from the pump, I would suggest that you either keep jetting up the primary until it stops pinging, or try a cooler plug. A plug is only too cold if the plug keeps fouling. You have to feed a hot plug with more fuel.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
