Jason I only ever owned one original wide lipped oval Hemi TA lid. It was NOS painted black, stamped "Made in Canada". It came from Fram with the first Hemi TA base I got. It went as a unit with one of the bases I sold in the mid 80's. I saw one other the very same at the Mopar Nats about 20 years ago. The guy was carrying it with a real Hemi TA base. A bunch of guys, myself included tried buying both but he was more less showing the assembly off to some of the vendors.
On a side note since you couldn't get AC with a Hemi car or 6 pak E-body fresh-air, but AC was an option with a 340/383 Challenger.... it would make sense that the air cleaner that made it to Hamtramk for such a car built would be the type Dan has and not a 4bbl shaker with the TA ring spotwelded.... and likely hand built in the Fram "hobby shop". Dan's car is after all coded for both AC and N94 and as he says the TA front lip would interfere with the compressor.
