Matt, thanks for the pics. You are an inspiration. My 68RR is almost as bad as yours so you are motivating me with this post. Question for you: do you need the rear window corners if you are replacing the whole quarter? I'll be replacing my roof with a donor and using the AMD quarters and filler panel, will I still need to get those outer corner peices at the bottom of the window? My inner corners are not too bad so I'll repair those but the outer is so far gone I can't tell what I'll need. Thanks! Also, anyone have any suggestions on how to swap out the roof? I have been debating mostly on the front; wether to just cut strait through the pillar and but weld the new one on maybe with a few backing plates inside, or should I try to separate the seams at the top of the windshield? The back I just plan on separating the inner/outer skin at the seams at the top of the 1/4.
