Still trying to get it ready for media blasting, if there is anybody out there that thinks this work is not really time consuming, I'm here to tell you it is. Finished welding in all the parts around the package tray and began the tedious task of grinding down all of the plug welds that I have done since I started putting it back together. You definitely have to put yourself in the "zone" for this process! . In order to break up that minotony I finished the repair on the rear tailpanel cross member and here is how that looked.
