When the cam gear is seated against the register on the cam, does the cam gear stand proud of the nose of cam?
I'm embarassed to say that there was no bolt holding the cam gear hub to the cam. Just a light press fit. I must have forgot to install it in 2020 when I put the gear drive in. Amazing that it worked. The hub had not moved on the cam, it was still flush.
[img]http://i.imgur.com/boeexFms.jpg[/img] 31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
