Originally Posted by Kern Dog
I just ordered the whole kit from Bergman Auto Craft. Small sector kit with the hybrid coupler and hose adapters.
I am quite anxious to drive the car with a tight steering box.
I used to have a '76 Camaro with some upgrades....
That car had the bigger sway bars from a Trans Am, HD coil springs and an IROC 12.7 to 1 steering box. Say what you want about GM products but that car flat out handled great. The steering response was fantastic. I was really hoping to make the Charger equal to or better than the Camaro but I've always been disappointed by the Firm Feel steering box. This is no fault on the company. They surely did the best that they could with this design.
For contrast.....
My '67 Dart has the stock power steering which as you know, is almost effortless. It works perfectly for street use and the off road trails I drive it on. I wouldn't change anything about it. Turning on dirt can feel like turning on ice or mud so an easy effort steering gear is just fine.
For the Charger, the higher effort magnified the feeling of the slop. This has been an eye opener for me. I thought the higher effort would be great. If there were no steering box options, I'd consider switching back to a milder Stage 2 box with stock Idler and Pitman arms to mask some of the slop.
I have a 72 Duster, the aforementioned 67 Dart and another 70 Charger, all with power steering. The "Jigsaw" Charger has Fast Ratio arms. All are factory original steering boxes, none leak so they are staying in place. All feel pretty good on the road.
What power steering pump do you have. I was told by Lee Power Steering that not addressing a matched pump is often the cause of the noises and issue people have. The Saginaw's are better than the TRW/Eaton round cans. Getting the pressure and flow dialed in is important.
Don't shorten the pump lines. Ever notice some factory power steering pump lines seem unnecessarily long? It IS necessary so the rubber line has more time to dampen the harmonics from the pump into the steering gear.
Sometimes you'll see a odd joint in the middle of a pressure line and it goes from one size hose to another. Seems stupid because it's another place for a leak.... Well, that's to damping the harmonics also.
