Yeah do not know the compression
But I attached the Cam specs if you can see it
Also the piston card disregard the hand writing some one was taking a note and used the card..
So your worried on the 190s?
I’ll finish the other cylinder leak downs tonight but I have to ask.
Why some folks say leak don’t tell much ya gotta do compression the another
Says compression won’t tell me much need to do leak down, gets a bit confusing.
Compression health if cylinder/rings I thought
Leak down health of same plus valves, seals, head gasket …?
Just asking so I am crystal and taking things out of context.
I have a set of R5671a-9 and -8s do you think the 8s will be ok to start
I realize the -10s were his nitrous plugs and are to cold.
Thanks again
