No problem man I wasn't looking for specifics, just wanted to know how to relate to your answer I appreciate it thank you.
I'm not to worried about sharing my stuff just want to ensure I'm getting anything fixed up that I need to is all.
I doubt I run into anything other than a grudge race here and there.
I'll get the pan vac installed to and see what it says and hopefully I can finally get to go play
barring the rest of the leak down, r still seeing oil on the new set of plugs.
Which I'm changing to hotter plugs to do a couple of motor pulls
