The other 2 intakes I have for a 6bbl are my Edelbrock factory 2 plane 6bbl and the Weiand P3690982 6bbl intake from the 70s, "Cross Flow" I believe it was called, but either would have to be ported to Max Wedge port size.
Neither of these can be ported to MaxWedge size without extensive welding and the Weiand with an airfilter is not going to fit your N96. If you must have a MaxWedge sixpack then just use the Modman,
In theory, there is no difference between theory and practice. In practice, there is.
