Re: 572 engine, PG or 727 trans?
[Re: AndyF]
#2977942
10/24/21 06:36 PM
10/24/21 06:36 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I'm working with a race team who is putting a 572 inch wedge (Indy block and heads) into a B body race car. Trying to decide to go with a PG or stay with the 727. I'm leaning towards the PG since they have a couple of other cars with glides in them so they have PG spare parts. Also, the PG can be built with an aftermarket case which is SFI legal while the 727 requires a blanket or shield. I'm not sure which will be quicker down the track. They bracket race so they car about consistency more than ET. My guess is that the PG should work just fine behind the 572 and it might be a tad bit more consistent since it only has one gear change. I am a dyed in the wool fan of Torqflites', but in this case I would go glide if possible. A Torqueflite loses consistancy due to the first shift coming up real quick and too much starting line ratio. If they can't find a glide trans then I would run a rear gear like a 3.73 to reduce SLR to about 9.0 with the Torqueflite. I had to go to an airshifter on an RPM switch to get consistant times, and even with a well prepped track and 15x33 goodyears sometimes my 60 ft might vary by .01 or more.
Entire Thread
AndyF
10/24/21 09:40 PM
pittsburghracer
10/24/21 10:05 PM
Tig
10/24/21 10:12 PM
440Jim
10/24/21 10:19 PM
AndyF
10/24/21 11:37 PM
Cab_Burge
10/25/21 04:20 PM
Al_Alguire
10/25/21 04:27 PM
CMcAllister
10/25/21 04:51 PM
fast68plymouth
10/25/21 04:55 PM
AndyF
10/25/21 06:28 PM
Cab_Burge
10/26/21 04:59 PM
Harry's Taxi 2
10/26/21 05:07 PM
Cab_Burge
10/26/21 05:11 PM
JERICOGTX
10/26/21 07:18 PM
sixpakdodge
10/26/21 07:26 PM
JERICOGTX
10/26/21 07:34 PM
fourgearsavoy
10/27/21 12:32 AM
Cab_Burge
10/27/21 01:10 AM
Al_Alguire
10/27/21 01:18 AM
sixpakdodge
10/27/21 11:06 AM
JERICOGTX
10/27/21 11:17 AM
Rapid588
10/27/21 01:23 PM
JERICOGTX
10/27/21 01:50 PM
R3 Racing
10/27/21 04:22 PM
slantzilla
10/28/21 12:16 AM
an8sec70cuda
10/28/21 12:20 PM
gregsdart
10/28/21 01:31 PM
dvw
10/28/21 01:56 PM
J_BODY
10/28/21 02:02 PM
gregsdart
10/24/21 10:36 PM
dvw
10/24/21 11:05 PM
Cab_Burge
10/24/21 11:09 PM
beezer
10/24/21 11:22 PM
Craig J
10/24/21 11:47 PM
B1Frank
10/25/21 02:46 PM
440Jim
10/25/21 05:18 PM
69dart
10/25/21 05:58 PM
FastmOp
10/25/21 06:03 PM
pittsburghracer
10/25/21 06:16 PM
CMcAllister
10/25/21 08:51 PM
Jeremiah
10/26/21 04:35 AM
moparfan
10/25/21 06:04 PM
AndyF
10/25/21 09:01 PM
CROWBAR
10/25/21 10:55 PM
JERICOGTX
10/26/21 12:32 AM
Cab_Burge
10/26/21 02:08 AM
dvw
10/26/21 03:28 AM
6PKRTSE
10/26/21 01:55 PM
Jeremiah
10/26/21 04:32 AM
JERICOGTX
10/26/21 11:27 AM
HardcoreB
10/26/21 12:00 PM
