Re: Electrical draw on new resto,,,,where to start,,,
[Re: JMCFAN]
#2956918
08/24/21 12:27 PM
08/24/21 12:27 PM
Posts: 10,755 North Dakota
6PakBee
North Dakota
I would have guessed it would be either the ammeter (P terminal) or the alternator terminal (J terminal) as they are connected to the battery directly. If you look at your wiring diagram, the alternator terminal leads to a splice in the wiring harness in the passenger compartment that feeds:
1) Ammeter 2) Ignition switch 3) Headlights 4) Fuse panel (always energized circuits)
It looks like it's one of them. Am leaning towards the Ammeter since its original.. have pulled the headlight switch plug...not sure that is sufficient. Pulled individual fuses...but not all at once...will try that. Also disconnect the 2 large flat white connectors ( ignition switch and turn signals) Is there another connector..? I'll look after breakfast. What I can't get my arms around is the 5 amp current. At that current you are dissipating over 60 watts of power. Typically you would be burning something up. Are you absolutely sure you are reading that correctly? That it's not 5 ma?
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
Entire Thread
JMCFAN
08/21/21 08:55 PM
Andrewh
08/21/21 09:20 PM
gtx6970
08/21/21 09:21 PM
metallicareload
08/21/21 09:25 PM
BigBlockMopar
08/21/21 09:41 PM
roadrunninMark
08/21/21 09:56 PM
JMCFAN
08/21/21 11:09 PM
charge70
08/22/21 10:26 PM
JMCFAN
08/22/21 10:27 PM
John_Kunkel
08/21/21 10:04 PM
JMCFAN
08/21/21 11:10 PM
TJP
08/22/21 12:38 AM
JMCFAN
08/22/21 03:14 PM
larrymopar360
08/22/21 03:22 PM
JMCFAN
08/22/21 03:34 PM
6PakBee
08/22/21 03:35 PM
gtx6970
08/22/21 04:09 PM
Andrewh
08/22/21 04:20 PM
JMCFAN
08/22/21 04:52 PM
moparx
08/22/21 05:10 PM
JMCFAN
08/22/21 04:55 PM
BDW
08/22/21 04:57 PM
JMCFAN
08/22/21 05:11 PM
Sniper
08/22/21 05:10 PM
JMCFAN
08/22/21 05:14 PM
NITROUSN
08/22/21 05:21 PM
JMCFAN
08/22/21 05:25 PM
NITROUSN
08/22/21 05:34 PM
JMCFAN
08/22/21 05:47 PM
JMCFAN
08/22/21 05:53 PM
NITROUSN
08/22/21 06:00 PM
Sniper
08/22/21 06:05 PM
6PakBee
08/22/21 06:09 PM
JMCFAN
08/22/21 06:30 PM
NITROUSN
08/22/21 06:34 PM
JMCFAN
08/22/21 06:40 PM
Sniper
08/22/21 06:50 PM
larrymopar360
08/22/21 08:23 PM
JMCFAN
08/23/21 11:36 PM
TJP
08/24/21 12:59 AM
JMCFAN
08/24/21 01:47 AM
Sniper
08/24/21 12:17 PM
6PakBee
08/24/21 02:57 PM
JMCFAN
08/24/21 03:27 PM
TJP
08/24/21 03:55 PM
JMCFAN
08/24/21 04:01 PM
GomangoCuda
08/24/21 04:05 PM
6PakBee
08/24/21 04:27 PM
JMCFAN
08/24/21 04:39 PM
6PakBee
08/24/21 06:28 PM
JMCFAN
08/24/21 06:37 PM
TJP
08/25/21 12:57 AM
larrymopar360
08/25/21 03:50 PM
JMCFAN
08/25/21 04:51 PM
moparx
08/25/21 04:59 PM
JMCFAN
08/25/21 05:43 PM
TJP
08/26/21 01:06 AM
larrymopar360
08/25/21 06:15 PM
NITROUSN
08/22/21 07:19 PM
