Re: Electrical draw on new resto,,,,where to start,,,
[Re: Sniper]
#2956303
08/22/21 01:14 PM
08/22/21 01:14 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Agree... will pull ignition switch cable next. Its the middle firewall harness that kills the draw...
You are making assumptions when you say "works fine". Something is not working fine and until you physically disconnect EACH item on the list and check you cannot assume it "works fine".
For example, your ignition could very well draw 7 amps in use, but is still drawing current when it should be off. So while it make "work fine" in start and run, it should not be drawing current at all in off. Until you disconnect it you won't know. [/quote]
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Entire Thread
JMCFAN
08/21/21 08:55 PM
Andrewh
08/21/21 09:20 PM
gtx6970
08/21/21 09:21 PM
metallicareload
08/21/21 09:25 PM
BigBlockMopar
08/21/21 09:41 PM
roadrunninMark
08/21/21 09:56 PM
JMCFAN
08/21/21 11:09 PM
charge70
08/22/21 10:26 PM
JMCFAN
08/22/21 10:27 PM
John_Kunkel
08/21/21 10:04 PM
JMCFAN
08/21/21 11:10 PM
TJP
08/22/21 12:38 AM
JMCFAN
08/22/21 03:14 PM
larrymopar360
08/22/21 03:22 PM
JMCFAN
08/22/21 03:34 PM
6PakBee
08/22/21 03:35 PM
gtx6970
08/22/21 04:09 PM
Andrewh
08/22/21 04:20 PM
JMCFAN
08/22/21 04:52 PM
moparx
08/22/21 05:10 PM
JMCFAN
08/22/21 04:55 PM
BDW
08/22/21 04:57 PM
JMCFAN
08/22/21 05:11 PM
Sniper
08/22/21 05:10 PM
JMCFAN
08/22/21 05:14 PM
NITROUSN
08/22/21 05:21 PM
JMCFAN
08/22/21 05:25 PM
NITROUSN
08/22/21 05:34 PM
JMCFAN
08/22/21 05:47 PM
JMCFAN
08/22/21 05:53 PM
NITROUSN
08/22/21 06:00 PM
Sniper
08/22/21 06:05 PM
6PakBee
08/22/21 06:09 PM
JMCFAN
08/22/21 06:30 PM
NITROUSN
08/22/21 06:34 PM
JMCFAN
08/22/21 06:40 PM
Sniper
08/22/21 06:50 PM
larrymopar360
08/22/21 08:23 PM
JMCFAN
08/23/21 11:36 PM
TJP
08/24/21 12:59 AM
JMCFAN
08/24/21 01:47 AM
Sniper
08/24/21 12:17 PM
6PakBee
08/24/21 02:57 PM
JMCFAN
08/24/21 03:27 PM
TJP
08/24/21 03:55 PM
JMCFAN
08/24/21 04:01 PM
GomangoCuda
08/24/21 04:05 PM
6PakBee
08/24/21 04:27 PM
JMCFAN
08/24/21 04:39 PM
6PakBee
08/24/21 06:28 PM
JMCFAN
08/24/21 06:37 PM
TJP
08/25/21 12:57 AM
larrymopar360
08/25/21 03:50 PM
JMCFAN
08/25/21 04:51 PM
moparx
08/25/21 04:59 PM
JMCFAN
08/25/21 05:43 PM
TJP
08/26/21 01:06 AM
larrymopar360
08/25/21 06:15 PM
NITROUSN
08/22/21 07:19 PM
