Re: Electrical draw on new resto,,,,where to start,,,
[Re: 6PakBee]
#2956338
08/22/21 02:30 PM
08/22/21 02:30 PM
Posts: 2,096 New Mexico
JMCFAN
New Mexico
Unless I am reading the wiring diagram incorrectly, the middle bulkhead connector has:
Ignition switch #1 Ignition switch #2 windshield washer turn signal switch ammeter temp gauge oil pressure gauge alternator
I'd leave the bulk head connector disconnected, make up a short jumper, and go through the terminals one at a time until you find the culprit. You are absolutely going to need a wiring diagram unless you are one of those lucky ones and just fall into it. There are two blacks in that connector, one larger than the other. That's the one I'm betting on as there is a splice on the passenger compartment side that feeds a bunch of things.
Just remember the alternator wire and the battery wire are tied together through the ammeter. That is a awesome idea!! I do have FSM and a stand alone wiring diagram
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Entire Thread
JMCFAN
08/21/21 08:55 PM
Andrewh
08/21/21 09:20 PM
gtx6970
08/21/21 09:21 PM
metallicareload
08/21/21 09:25 PM
BigBlockMopar
08/21/21 09:41 PM
roadrunninMark
08/21/21 09:56 PM
JMCFAN
08/21/21 11:09 PM
charge70
08/22/21 10:26 PM
JMCFAN
08/22/21 10:27 PM
John_Kunkel
08/21/21 10:04 PM
JMCFAN
08/21/21 11:10 PM
TJP
08/22/21 12:38 AM
JMCFAN
08/22/21 03:14 PM
larrymopar360
08/22/21 03:22 PM
JMCFAN
08/22/21 03:34 PM
6PakBee
08/22/21 03:35 PM
gtx6970
08/22/21 04:09 PM
Andrewh
08/22/21 04:20 PM
JMCFAN
08/22/21 04:52 PM
moparx
08/22/21 05:10 PM
JMCFAN
08/22/21 04:55 PM
BDW
08/22/21 04:57 PM
JMCFAN
08/22/21 05:11 PM
Sniper
08/22/21 05:10 PM
JMCFAN
08/22/21 05:14 PM
NITROUSN
08/22/21 05:21 PM
JMCFAN
08/22/21 05:25 PM
NITROUSN
08/22/21 05:34 PM
JMCFAN
08/22/21 05:47 PM
JMCFAN
08/22/21 05:53 PM
NITROUSN
08/22/21 06:00 PM
Sniper
08/22/21 06:05 PM
6PakBee
08/22/21 06:09 PM
JMCFAN
08/22/21 06:30 PM
NITROUSN
08/22/21 06:34 PM
JMCFAN
08/22/21 06:40 PM
Sniper
08/22/21 06:50 PM
larrymopar360
08/22/21 08:23 PM
JMCFAN
08/23/21 11:36 PM
TJP
08/24/21 12:59 AM
JMCFAN
08/24/21 01:47 AM
Sniper
08/24/21 12:17 PM
6PakBee
08/24/21 02:57 PM
JMCFAN
08/24/21 03:27 PM
TJP
08/24/21 03:55 PM
JMCFAN
08/24/21 04:01 PM
GomangoCuda
08/24/21 04:05 PM
6PakBee
08/24/21 04:27 PM
JMCFAN
08/24/21 04:39 PM
6PakBee
08/24/21 06:28 PM
JMCFAN
08/24/21 06:37 PM
TJP
08/25/21 12:57 AM
larrymopar360
08/25/21 03:50 PM
JMCFAN
08/25/21 04:51 PM
moparx
08/25/21 04:59 PM
JMCFAN
08/25/21 05:43 PM
TJP
08/26/21 01:06 AM
larrymopar360
08/25/21 06:15 PM
NITROUSN
08/22/21 07:19 PM
