Re: Electrical draw on new resto,,,,where to start,,,
[Re: 6PakBee]
#2956895
08/24/21 11:27 AM
08/24/21 11:27 AM
Posts: 2,096 New Mexico
JMCFAN
New Mexico
I would have guessed it would be either the ammeter (P terminal) or the alternator terminal (J terminal) as they are connected to the battery directly. If you look at your wiring diagram, the alternator terminal leads to a splice in the wiring harness in the passenger compartment that feeds:
1) Ammeter 2) Ignition switch 3) Headlights 4) Fuse panel (always energized circuits)
It looks like it's one of them. Am leaning towards the Ammeter since its original.. have pulled the headlight switch plug...not sure that is sufficient. Pulled individual fuses...but not all at once...will try that. Also disconnect the 2 large flat white connectors ( ignition switch and turn signals) Is there another connector..?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Entire Thread
JMCFAN
08/21/21 08:55 PM
Andrewh
08/21/21 09:20 PM
gtx6970
08/21/21 09:21 PM
metallicareload
08/21/21 09:25 PM
BigBlockMopar
08/21/21 09:41 PM
roadrunninMark
08/21/21 09:56 PM
JMCFAN
08/21/21 11:09 PM
charge70
08/22/21 10:26 PM
JMCFAN
08/22/21 10:27 PM
John_Kunkel
08/21/21 10:04 PM
JMCFAN
08/21/21 11:10 PM
TJP
08/22/21 12:38 AM
JMCFAN
08/22/21 03:14 PM
larrymopar360
08/22/21 03:22 PM
JMCFAN
08/22/21 03:34 PM
6PakBee
08/22/21 03:35 PM
gtx6970
08/22/21 04:09 PM
Andrewh
08/22/21 04:20 PM
JMCFAN
08/22/21 04:52 PM
moparx
08/22/21 05:10 PM
JMCFAN
08/22/21 04:55 PM
BDW
08/22/21 04:57 PM
JMCFAN
08/22/21 05:11 PM
Sniper
08/22/21 05:10 PM
JMCFAN
08/22/21 05:14 PM
NITROUSN
08/22/21 05:21 PM
JMCFAN
08/22/21 05:25 PM
NITROUSN
08/22/21 05:34 PM
JMCFAN
08/22/21 05:47 PM
JMCFAN
08/22/21 05:53 PM
NITROUSN
08/22/21 06:00 PM
Sniper
08/22/21 06:05 PM
6PakBee
08/22/21 06:09 PM
JMCFAN
08/22/21 06:30 PM
NITROUSN
08/22/21 06:34 PM
JMCFAN
08/22/21 06:40 PM
Sniper
08/22/21 06:50 PM
larrymopar360
08/22/21 08:23 PM
JMCFAN
08/23/21 11:36 PM
TJP
08/24/21 12:59 AM
JMCFAN
08/24/21 01:47 AM
Sniper
08/24/21 12:17 PM
6PakBee
08/24/21 02:57 PM
JMCFAN
08/24/21 03:27 PM
TJP
08/24/21 03:55 PM
JMCFAN
08/24/21 04:01 PM
GomangoCuda
08/24/21 04:05 PM
6PakBee
08/24/21 04:27 PM
JMCFAN
08/24/21 04:39 PM
6PakBee
08/24/21 06:28 PM
JMCFAN
08/24/21 06:37 PM
TJP
08/25/21 12:57 AM
larrymopar360
08/25/21 03:50 PM
JMCFAN
08/25/21 04:51 PM
moparx
08/25/21 04:59 PM
JMCFAN
08/25/21 05:43 PM
TJP
08/26/21 01:06 AM
larrymopar360
08/25/21 06:15 PM
NITROUSN
08/22/21 07:19 PM
