I have the frame stripped down to where I can start planning to shorten it. From what measurement I have taken so far I am going to shorten the frame where the front box mounts are located. The cab opening from the frame won't clear the old cab mounts but I still have a bit more measuring to do to see if I can just cut the old cab mounts off and use the box mounts where they are. I wish the next few weeks were as fun and quick as the last week of just stripping the truck down but I know that wont be the case. I will keep posting pictures as the build goes on.
