If it cant hit the tire hard enough travel can help. Loose on the other hand usually just unloads when it tops out. As long as it is rising, the front is adding transfer. Once the wheels are off the ground shocks and springs mean zero. If you don't have enough power to keep it up in the air, now your in trouble. Doug
