Originally Posted by HP2
Originally Posted by BSB67
Solid flat tappet. Comp cam: XS268S. Pretty mild, and easy on parts.
This is an internet amatur's recommendation from a catelog. I would suggest calling a professional.
I have also been looking at that one, it's mechanical. Very close to Hughes SEH2024BL-11 but more duration and a little less lift. Plus I'm not sure Comp grind their Mopar cams for the larger .904 lifters...
I'm going to tell you that I have been told, and saw it on here also, that Hughes has Comp grind al their cams for them so that being said I'm sure that all the cams Cp sells are designed around the .904 lifter size up scope
