I have a clutch Flite going in my current project, runner with 528 cubes. It’s the car in my avatar. I am hoping it will be ready prior to winter. The Flite is the fairbanks version, I think built in the early 2000s. I’ve had it for quite a long time so it will very interesting when the car is ready. I got a clutch setup, twin disc from McCleod.
Trendz- will your unit have the same input shaft as a typical clutch flite? If yes, would you consider making an extra input shaft or two to sell? I wouldn’t mind having an extra one or two just in case. I don’t know what drum is in it, I did have the plates refreshed a while ago but that is about it.
I will be using an old Anson blowproof bell. I have a trans body shield but I was thinking of not using it. I wont be racing the car, but should I use the body shield any way? I dont know it hits the tunnel or not.
That is a pretty stout clutch I hope it doesn't dead hook. I broke a HEMI box with that clutch before I knew better about having slip in the drivetrain somewhere.
Gus
