Yes it is a Denso 210-0177 alternator which was OE on the Land Cruiser for a few years. It came with a dual belt pulley. I machined the front pulley off and kept the inner one. The OE pulley is made from steel and is super heavy.
Is that a one wire hookup?
I usually hook up an external switched 12 volt and a sense wire. It is just two wires to run so most anyone should be able to handle it.
