I'm making some progress on the motor mounts. Mostly I've figured out what won't work so I'll count that as progress. I have a fixture to hold the engine in the correct location while I bend up different shapes. The Borgeson PS box is in place and it seems to fit okay. I'm not so sure I like the angle that Borgeson puts these boxes at, it looks odd and it will force the couple to flex a few degrees every time the steering wheel is turned but I guess they designed it that way for a reason. I did have to trim one of the motor mount lugs on the block to clear the steering box but that didn't take too much time. The headers appear to clear the PS box by a fair amount. I did get the entire steering column rebuilt and rewired so it should be good to go. Also got new gaskets and seals for everything involved.
