I was going to use a mini-starter but it sits pretty close to the Schumacher header so I decided to try a starter from RobbMc. The RobbMc starter is completely different and has a lot of room around it. I'll have to change my wiring setup but I guess I can do that. This is just how it goes with custom projects. You try different combinations of parts until you find something that works well enough. None of this stuff is ever perfect, but if you try enough different combinations you can eventually find something that fits and works. Kind of time consuming (and expensive) process though.
