Re: Winter update for the Coronet
[Re: Cab_Burge]
#2651948
05/04/19 04:59 PM
05/04/19 04:59 PM
Posts: 31,073 Oregon
AndyF
Why are you using the C and A body BB driver side motor mounts? Because it is the only bracket that fits.
[Re: AndyF]
#2691483
08/26/19 09:54 AM
08/26/19 09:54 AM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Andy is that the Land Cruiser alternator? Did you make a pulley or are you using the dual pulley setup? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#2691519
08/26/19 11:17 AM
08/26/19 11:17 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Yes it is a Denso 210-0177 alternator which was OE on the Land Cruiser for a few years. It came with a dual belt pulley. I machined the front pulley off and kept the inner one. The OE pulley is made from steel and is super heavy. Is that a one wire hookup?
[Re: cudadoug]
#2691546
08/26/19 12:15 PM
08/26/19 12:15 PM
AndyF
Yes it is a Denso 210-0177 alternator which was OE on the Land Cruiser for a few years. It came with a dual belt pulley. I machined the front pulley off and kept the inner one. The OE pulley is made from steel and is super heavy. Is that a one wire hookup? I usually hook up an external switched 12 volt and a sense wire. It is just two wires to run so most anyone should be able to handle it.
[Re: AndyF]
#2691723
08/26/19 09:12 PM
08/26/19 09:12 PM
Posts: 1,543 USA
hudsonhornet7x
USA
The Corvette PS housing is flat on the back and it sits forward of the motor plate so it should be fairly easy to mount it to a motor plate. Not very many cars use a motor plate and power steering at the same time so I doubt I'll bother with creating a bracket kit. Thanks for the information. Mine will need both.
[Re: hudsonhornet7x]
#2691724
08/26/19 09:16 PM
08/26/19 09:16 PM
AndyF
If you are working with a BB or a Hemi then there should be plenty of room. Just buy one of those pumps and a pulley and hang it in space so the belt is straight. You'll probably have about one inch of room behind the pump for the bracket. You'll have to figure how how you want to tension the belt. Any good street rod shop should be able to fabricate a mount for you. If you are working with a G3 then mounts already exist to use this pump.
[Re: AndyF]
#2691842
08/27/19 08:15 AM
08/27/19 08:15 AM
Posts: 1,543 USA
hudsonhornet7x
USA
If you are working with a BB or a Hemi then there should be plenty of room. Just buy one of those pumps and a pulley and hang it in space so the belt is straight. You'll probably have about one inch of room behind the pump for the bracket. You'll have to figure how how you want to tension the belt. Any good street rod shop should be able to fabricate a mount for you. If you are working with a G3 then mounts already exist to use this pump. Thanks, I was thinking rather the same thing. The setup looks good.
[Re: AndyF]
#2692515
08/29/19 08:08 AM
08/29/19 08:08 AM
Posts: 1,543 USA
hudsonhornet7x
USA
Here is a picture showing the back side of the PS pump. There is about 1.5 inches of space behind the pump to the front of the block so there is plenty of space to build a bracket that would mount on a motor plate. Yep, Thanks for the picture. I think that would make for a clean installation.
[Re: AndyF]
#2693067
08/31/19 04:38 AM
08/31/19 04:38 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
Yes, I use 12 point ARP stainless on all of my builds. The ARP Fasteners are the best I have found, And the 12 point fasteners are very appealing to the eye as well as very high quality.
