To many variables for one correct answer, it depends on where the hole in the component ended up the position of the pin installer & whom he was the tool in his hand ETC ETC, for the most part they did what ever was quickest & whacked it over in the direction that was easiest at any given component/position & it wasn't supposed to look pretty, just do the same for your car.
