Quote: Dave, just a question/suggestion, and if it's not doable or doesn't meet your preference for the car I'll understand, but do you think it's possible to LOWER the headlights on the grille shell as in my revised pic? To my eye the looks of the front end are improved/cleaned up with the headlights lower in relation to the fender...
Bruce, the only problem is that the headlights are actually the end of the chrome piece and the finish panel for that long chrome. I can go out and check and see how it will look and if it will look OK without the chrome pieces on it.
