Originally Posted by fast68plymouth
Basically, the 4 runners that have the sharpest turn coming out of the plenum flow the least...... the “inner” runners.
3,5,4,6.
I’d have to dig out my notes since I did that testing quite a while ago, but that’s how I remember it.
Not really much difference between upper and lower.
That’s tested as bolted to a ported head, and comparing how much flow is lost with the manifold in place(and it loses a bunch).
The overall best one I’ve tested was extensively modified by Jim Sieler for his Dart.
His motor was a very high effort build with several pretty high dollar parts in it....... and it made quite good power on the dyno.
He never quite got the car sorted out well enough to use all the power he had.
I’m sure if he would have stuck with it, there would have been some very low 11-sec ET’s...... and maybe even a “10” at MIR on a killer day.
He’s also a fun guy to have around at the track....... wish he was still playing in those classes.
Quote
if you find a link to the guys 451 build can you post a link?
It’s roadrunner2’s motor, in his car.
Edit: this is why it’s best not to go by memory.......
On a mildly reworked 301, all the ports lost about 20-21% compared to the head by itself(about 50cfm).
It looks like the % of loss is within about 1% for all runners, on one that has what I would consider a “normal” amount of rework.
At that level of rework, on a head that flows solidly over 280cfm, its about an 18cfm improvement avg for all 8 runners over the untouched manifold.
Jim’s intake averaged 13cfm better than the one with the “normal” rework, although some of his ports flowed over 30cfm better than the same runner on the one with normal porting.
What brought the average down was there were two runners that showed minimal improvement at all over the stock intake.
Runners #1 and #7.
To put it in perspective, the 8cyl flow average for the head with a radius plate was 286.7cfm.
The intake was tested bolted to the head with all ports blocked off except the one being tested, and a Holley 1000cfm 4150 carb mounted to the carb pad.
The 8cyl flow average for the stock manifold was 212.8cfm.
The 8cyl flow average for the normally ported manifold was 230.7cfm.
The 8cyl flow average for an ootb Performer RPM was 250.6cfm.
If Jim could have picked up #1 and #7 about 15cfm..... the 8cyl flow average would have been right there with the RPM.
Some of the runners on a cleaned up Victor only lost a few cfm compared to the head with the radius plate.
That’s exactly the info I wanted, thanks D.
Bill
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’
Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST.
10:1 451” replaced with 14:1 499”.
