4.2 lever, controlled load defeated w set screw 1.25 turns out
Kinda tight. 1.75 would be better.
John thank you so much for carefully reading my buildup specs and offering a helpful change on the kickdown band adjustment. Plus it’s a real easy one to fix!
Moparax like John said the kit replaces the flimsy steel collar with a nice billet piece. It’s not overly thick but plenty to stay rigid and do the job. I had to re-use the blocker and spring from my tf2 modded stock setup but the AA kit had the piston with seals installed, the retainer plate, and a new snapring. Plus photocopied instructions.
It is so nice to have the trans buttoned up and be able to make sawdust and do metal fabrication again in my little garage!
Much thanks for all the support here
Radar
