Do you plan to put some plastic caps over the tops of the fender mounted battery studs? You never know where a dropped wrench will fall under the hood.
Yes as that's a very good idea. I had my voltmeter clips on them checking the charging system and I noticed they can actually touch each other if not careful. So we will be doing that real soon. Ron
