Re: 73 Charger won’t run, any help appreciated
[Re: cdwmotorsports]
#2620060
02/11/19 11:53 PM
02/11/19 11:53 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
It may be wrong to assume that you have oil in, and an oil filter on the motor? Spin the oil pump to prime the oil system.
I'd bring #1 up on compression and make sure it didn't jump the timing chain. Pull the plugs ans put a little oil into each cylinder, then spin the motor over with the starter. Bring # 1 back up on compression, install new plugs, and be sure the ignition wires are connected to the proper cylinders, in the proper rotation, and in the proper position. Check for spark. If you have compression, spark at the right place at the right time, all you should need is fuel, use gas. Fill the carb float bowl and try to start it. Gene
Entire Thread
73 Charger running NOW!!! All help appreciated
cdwmotorsports
02/11/19 10:19 PM
PurpleBeeper
02/11/19 11:41 PM
cdwmotorsports
02/12/19 12:32 AM
Fat_Mike
02/12/19 12:40 AM
RapidRobert
02/12/19 01:52 AM
cdwmotorsports
02/12/19 02:46 AM
poorboy
02/12/19 03:53 AM
cdwmotorsports
02/12/19 04:13 AM
RapidRobert
02/12/19 05:38 AM
bboogieart
02/16/19 06:19 PM
cdwmotorsports
02/17/19 01:38 AM
JMCFAN
02/17/19 01:57 AM
cdwmotorsports
02/17/19 02:08 AM
JMCFAN
02/17/19 02:12 AM
NITROUSN
02/17/19 04:04 AM
cdwmotorsports
02/17/19 04:31 AM
bboogieart
02/17/19 02:02 AM
cdwmotorsports
02/17/19 02:06 AM
SattyNoCar
02/12/19 05:43 AM
cdwmotorsports
02/12/19 06:38 AM
SattyNoCar
02/12/19 04:03 PM
cdwmotorsports
02/12/19 06:40 AM
stumpy
02/12/19 07:34 PM
cdwmotorsports
02/12/19 09:11 PM
SattyNoCar
02/12/19 09:45 PM
TC@HP2
02/12/19 09:47 PM
JMCFAN
02/13/19 01:02 AM
sasquatch
02/12/19 10:18 PM
Sunroofcuda
02/13/19 02:58 AM
moparx
02/13/19 06:38 PM
cdwmotorsports
02/16/19 03:41 AM
moparx
02/16/19 05:12 PM
cdwmotorsports
02/16/19 05:15 PM
slantzilla
02/17/19 03:09 AM
cdwmotorsports
02/17/19 03:41 AM
cdwmotorsports
02/16/19 03:43 AM
Powerflow
02/16/19 05:04 AM
rhad
02/16/19 07:15 AM
stumpy
02/17/19 04:37 AM
cdwmotorsports
02/17/19 04:50 AM
stumpy
02/17/19 05:03 AM
cdwmotorsports
02/17/19 06:13 AM
SattyNoCar
02/17/19 06:26 AM
NITROUSN
02/17/19 05:15 AM
Pacnorthcuda
02/17/19 04:54 AM
poorboy
02/17/19 06:23 AM
cdwmotorsports
02/17/19 06:33 AM
rhad
02/17/19 06:44 AM
slantzilla
02/17/19 06:45 AM
buildanother
02/17/19 12:06 PM
cdwmotorsports
02/17/19 03:15 PM
Fat_Mike
02/17/19 07:39 PM
mopars4ever
02/17/19 07:18 PM
RapidRobert
02/17/19 07:40 PM
cdwmotorsports
02/17/19 09:28 PM
Porter67
02/17/19 07:57 PM
Supercuda
02/17/19 08:24 PM
moparx
02/18/19 05:57 PM
cdwmotorsports
02/21/19 02:16 PM
stumpy
02/21/19 05:40 PM
mopars4ever
02/21/19 06:35 PM
cdwmotorsports
02/25/19 04:26 AM
moparx
02/25/19 06:16 PM
TC@HP2
02/26/19 11:55 PM
cdwmotorsports
02/27/19 02:59 AM
Fat_Mike
02/27/19 05:32 PM
cdwmotorsports
03/14/19 01:27 AM
DynoDave
03/14/19 08:38 PM
SattyNoCar
03/16/19 02:34 AM
cdwmotorsports
03/17/19 12:13 PM
moparx
03/17/19 03:29 PM
cdwmotorsports
03/19/19 10:54 PM
cdwmotorsports
03/23/19 01:00 AM
moparx
03/23/19 01:50 PM
cdwmotorsports
03/23/19 03:34 PM
Fat_Mike
03/23/19 06:01 PM
bboogieart
03/23/19 08:50 PM
moparx
03/24/19 03:33 PM
DynoDave
03/24/19 06:05 PM
Re: 73 Charger running NOW!!! All help appreciated
cdwmotorsports
04/11/19 02:07 AM
DynoDave
04/12/19 03:15 PM
